Question about Sony Ericsson Walkman W810i Cellular Phone
No bluetooth will not stay connected to my w810i, I have tried both of my headsets (lg) and (se), they connect for about 5 or 6 seconds then disconnect
I'm trying to connect to my LG Rumor 2 with my 220 PLANTRONICS
First you want to make sure there is no other Bluetooth interference in your phone. Turn off your headset and phone (remove the battery from the phone for about 30 seconds, if possible, to reset). Follow the pairing instructions found on this link for the Plantronics Explorer 220 User's Guide -- pages 3-5, 7.
Good luck from Headsets Direct!
Sep 15, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My LG cookie is not able to detect the Nokia Bluetooth headset
Sorry if you have done this but let's see if we can get you connected!
On your Nokia headset press and hold the multi-function key for roughly 8 seconds. Your green light will begin to flash quickly. Your Bluetooth headset is now in pairing mode.
Now using your LG Cookie, press Menu > Settings > Bluetooth > Search
Once found, you will need to type the pass code which is normally set as four zeros (0000).
You should now be connected.
We hope this helps!
Jul 03, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
How do I connect hands free blue tooth to an LG incite
hold the on button on your bluetooth headset until it blink and stay lighted then turn you cellphone bluetooth on and click search for bluetooth device. your bluetooth headset should appear then click connect
Jun 08, 2009 | LG Incite Cell Phone
I will attach motorola h700 wireless bluetooth connected to sonyericsson w810i media player not working the bluetooth wireless
go to the bluetooth option in the w810i and delete all the devices enlisted under my devices..then do a fresh search and pair it again,,connect it.tats it..if it doesnt work,,contact the manufacturer coz it will b hardware problem
Apr 16, 2009 | Motorola Mobility H700 Wireless Headset
HOW DO I PLACE AN LG BLUETOOTH HBM710 IN "DISCOVERY MODE" ?
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
Apr 03, 2009 | LG HBM-710 Wireless Headset
Bluetooth wont stay connected
probably a hardware issue on the phone itself...
i would call up lg support first ask them why is this...
bluetooth does have a 10m range and connecting a bluetooth headset shouldnt be as far as 10m
Aug 21, 2008 | LG Shine CU720 Cellular Phone
HBM 750 BLUE LIGHT STAY ON
I have the same model, and if you turn it on and the light stays on, usually after a flash and about 10 seconds, your headset isn't paired with your phone. You need to re-pair it with your cell phone, the code is 0000. That should work.
Jun 29, 2008 | LG HBM 730 Bluetooth Headset Wireless...
SE w810 internet connection VIA bluetooth to computer
i want to know that how is speed to connect internet via bluetooth in w810i Sony Ericsson Walkman phone
Jun 28, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Pairing with my Sony Ericsson w810i's MP3 player
hi stefan,
sorry to let you know but sony w180 does not suort an A2DP profile,
which is necessary to listen music wirelessly. so u'll have to change ur handset if
u want to listen to music via ur bluetooth headset.!!
good luck!
Dec 11, 2007 | GN Netcom GN Jabra BT620s Bluetooth Stereo...
Bluetooth Connection
on the jabra head set press and hold the button for about 3 seconds and then the blue light on the headset should stay illuminated. Then go to your phone and search devices, when your phone finds the jabra, you may have to put in a pairing code normally four noughts,zeros (0000), when inputed the headset blue light should change from a solid light to a intermittent flashing light, showing on your phone that the connection is succesful.
Aug 13, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
