Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
WESTERN DIGITAL WHEN I PLUG IN MY WESTERN DIGITAL HD IT DOESN'T APPEAR ON MY COMPUTER NOR AUTO DETTECT, ITS RUNNING FINE THE LIGHT IS ON I CAN HEAR THE FAN BUT ITS NOT DETECTING. BUT THE SMALL ICON WHICH YOU USE TO REMOVE THE DRIVE APPEARS NEAR THE TIME IN THE RIGHT HAND CORNER, PLEASE HELP ME TO FIX IT
  • BPADDLE Mar 16, 2009
    I'm having the exact same problem, did you ever find a solution? I'm in contact with someone on the support website but they haven't been any help so far...
I'm having the same problem i did hat you said but nothing happen i Have a HP dv1000 the light is on the fan is running but nothing is there another way i have a portable hard drive 120GB
Posted on Jan 25, 2008
  • 233 Answers
Wiggle the cable connected to the drive gently up and down and side to side
I have the same problem with one of my drives, by doing the above it works. I think the connector inside "the conatcts" don't make good contact with the cable
thanks for rating
Posted on Jan 09, 2008
  • Pedro
    Pedro Jan 20, 2008
    How is my suggestion "Inappropriate'?
    Di you ever think that maybe your description is not sufficient?
It doen not turn on completly. The green light blinks about every 5 seconds but doesn't turn on.
it is not getting enough power. Use a two ended USB plug (both ends into computer) one into HD, or use external power adapter
Jul 10, 2011 | Western Digital My Book Essential Edition...
If i plug my player to pc it shows charging and full charge but if i disconnect it will appear lowbat in the screen. and my pc doesn't dettect my unit
Try turning off the player and then back on again. The battery status should update and show full charge. Restart your PC and reconnect the player and it should appear again.
Simply pulling out the USB cable can cause a communication error, so it's always best to use the 'Eject USB device' option. When you want to disconnect, the player will be listed as an external hard drive when you open up 'My Computer', right click on the drive and select 'Eject'.
Jun 13, 2011 | SanDisk Sansa Clip MP3 Player
I have the Western Digital fire wire 500GB. Once it's plugged in it shuts off after about 7 seconds. I see a light flicker inside and it goes out too.
all external HD need power to run. is this running on AC, USB or Firewire........ if USB or Firewire is your computer compatible with the HD power needs if it is compatible
and if this is straight out the box, return it is defective........
Apr 10, 2011 | Western Digital Computers & Internet
I have a WD external driver for my PC. It is an old version about 2006. I connect it with my computer, there is a blue light that means it is connected(kinda reads it) but it doesn;t show the driver...
dear listen to hd when it work if you hear a low tike that is mean its damaged
if no tik do that write click on my computer - manage - disk manaement see your hd if itsn't appear that need a mantinance engneer
best regardes
if you see that is helpefull plz vote me
Mar 28, 2011 | Western Digital My Book Essential Edition...
MyBook 2TB used as backup drive and connected via FW to other external HD. Had been powered off for a couple of months When powered up again, it does not show as a device (Mac OSX 10.6.4). Front light...
I would listen to the enclosure near your ear to see if you hear any "spinning up noises." Or if you hear "clicking" or "buzzing or beeping." Just to verify the drive is okay. It could have gone bad; being it is so new, it would be under warranty replacement. Also, connect the drive up to another computer in an effort to see if the interface is okay. There could be a problem with the usb controller inside the Mybook. HOwever, once you open it - the warranty is void. Lastly, you could send it to a data recovery company and see if they will diagnose it. Western Digital has a list of approved recovery companies on their website.
Oct 16, 2010 | Western Digital My Book Essential Edition...
Hard drive will not turn on, light blinks
sounds like the powerboard bit is knackered on the case try taking the drive out the case and buying a hd caddy sata 2 usb
Jan 01, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
I have WD 160GB external hard drive. when i plug in to the computer.it shows on the taskbar as USB storage device but without an assined letter . on my computer window shows nothing about the external hard...
Attach your external HD with some other computer, that will definitely appear normal, the problem is due to a virus in ur HD. Your computer's antivirus software stops it to appear. Back up your data on the other computer, format ur external HD, remove un-necessary files and run a virus scan to the files u copied from HD, Hope this will solve the problem, if not, let me know and tell me what would be the response on the other compuer
Sep 20, 2009 | Western Digital 160GB 7200RPM HDD WD1600BB...
HD doesn't work on other computer
Go into my computer, right click, hit refresh and click on the hd
Jan 10, 2009 | Western Digital Passport WDXML800UE...
WD Passport appear as an unknown device
try it again, after going to wd dot com, and getting and installing a new set of drivers..
Oct 13, 2008 | Western Digital Computers & Internet
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
228 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
