Question about Garden
Lawn mower starts and stops right away
I have a new yard machine lawn mower. The first time I used it, it worked fine. I waited for nearly a month and tried to use it for a second time. It started without problem when primed, but stopped right away. It won't start if I don't push the primer. If I keep on pushing the primer, the engine would run (roughly), but the engine would stop as soon as I stop pushing the primer. I took out the gas and filled with fresh gas. The problem stays without any improvement. Any suggestions on what is wrong are very welcome. Thanks in advance.
  • 317 Answers
Take bowl off bottom of carb....clean and reassemble
Posted on Nov 17, 2009
Testimonial: "Thanks. That is the consensus from the research I have done. I will try to do it when I get a chance. "
My Yard Machine lawn mower stops working. I can start it if I press the gas button a few times but it would stop running right away. The gas is not reaching the engine. I opened the air filter and found...
the red tube should just slide over a tube sticking out of the carburetor or the plastic housing on the breather.all you do is plug it in. if that dont fix it my guess is there is debris in the carburetor that needs to be cleaned. take it apart clean and it should run as like new
Nov 23, 2017 | Mtd 22" Yard Machine Push Mower
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
22" yardmachine starts and stops
loosen the bolt on the bottom of the carburetor up and let the water out and then re tighten and try it
Jul 22, 2009 | Mtd 22" Yard Machine Push Mower
GOT GASOLINE IN OIL TANK OF MY LAWN MOWER BY ACCIDENT. sTARTED THE MOWER ONCE .IT STARTED BUT GAVE A GREY SMOKE AND DIED.I HAVE A MACHINE YARD MOWER FROM MTD.IT IS 22'' SIDE DISCHARGER.PLEASE...
Empty the tank of the tainted gasoline (Maybe add the right amount of oil and use it for a trimmer, etc), fill tank with fresh gas and clean the spark plug, since it is probably fouled out. You may have to clean the carb with some carb cleaner, and clean your plug a few extra times, but it should be fine. Hope this helps. Good luck.
Jul 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
Mar 24, 2009 | Mtd 22" Yard Machine Push Mower
Requires several times just to get started and then runs fine for about 5-minutes and cuts then cuts out on its own. Then have to wait for about 10-15 minutes to start again but still requires several...
The most likely problem is the ignition module. It is probably going out. when a bad ignition module gets hot from use, it stops working, which kills the lawn mower since there is no spark. Once it cools off it sometimes works. This can be a some what costly part, $60 - $80. You might want to take it to a lawnmower repair shop and have them check it out, since there are other issues that could be the cause to your problem. If you have a spark tester, you could test the ignition module to see if you get spark, both before you start the mower, and after it quits on you.
Mar 10, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
1,123 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
