Question about Samsung SGH-G600 Cellular Phone
Problems sending and receiving sms in Argentina
I am currently in Argentina and have tried to send text messages to The Netherlands and Ecuador. They get sent but the recipients do not receive them. When they send me messages I do not receive them either. Any ideas as to what may be wrong?
My text messaging quite sending. i still get but can't send
text messages not sending - Android Forums at AndroidCentral.com
forums.androidcentral.com > LG Android Phones > LG G3
Nov 11, 2014 - 6 posts - ‎3 authors
So I've had my g3 since launch, I love it. However several times a day it takes several minutes to send or receive a message. I'm not quite sure ... text message issues
Apr 18, 2015
Why are my SMS & MMS receiving but not sending ...
Mar 22, 2015
Can't send text messages
Nov 15, 2013
Text Messages Not Sending?
Jun 10, 2011
More results from forums.androidcentral.com
I'm unable to send SMS (text) messages from my Samsung ...
www.samsung.com/ie/support/skp/faq/1031466
Samsung Electronics
Jan 20, 2016 | Cell Phones
I cant send or receive pictures through my sms
SMS stands for short message service. Simply put, it is a method of communication that sends text between cell phones, or from a PC or handheld to a cell phone. The "short" part refers to the maximum size of the text messages: 160 characters (letters, numbers or symbols in the Latin alphabet). For other alphabets, such as Chinese, the maximum SMS size is 70 characters.
From
http://computer.howstuffworks.com/e-mail-messaging/sms.htm
Oct 29, 2015 | Cell Phones
Sms restriction 45
TracFone International Texting Revoked
  • Certain mobileicon1.png phone upgrades affect the ability of TracFone customers to send text messages internationally. Some of the phones identified to have had this SMS issue are the LG290C, LG420G and Samsung T301G. The problem is present when an error message appears on your TracFone device after you send a text message to an international number that says, "Check SMS Restrictions."
Read more : http://www.ehow.com/info_8634048_trac-phone-problems.html Did you upgrade from the 420G to 440G? Certain mobile phone upgrades affect the ability of TracFone customers to send text messages internationally. Some of the phones identified to have had this SMS issue are the LG290C, LG420G and the Samsung T301G. The problem is present when an error message appears on your TracFone device after you send a text message to am international number that says, "Check SMS Restrictions"
Or your phone isn't capable of texting internationally.If it's supposed to then you need to call Tracfone customer service and tell them.
Mar 12, 2014 | Tracfone Wireless LG 440G
Text messages (SMS) remain on "Sending"
Probably a connection issue. Ask your network supplier.
Mar 20, 2017 | Samsung Galaxy Cell Phones
I cannot send nor receive calls, nor send and receive text messages as of yesterday, April 18, 2011... I am currently using a postpaid SIM... thanks
there are several factors why you are unable to send and receive messages and make outgoing calls and receive incoming calls.
network issue: are you the only one experiencing the problem? try to check with someone who is on the same location and is using the same network as you if he or she is experiencing the same problem as you. if yes, then it may be a problem with your network.
make sure that you have good signal and contact your service provider too and ask them if they have an ongoing maintenance in the area and ask if the sms and calls services are activated on your account
phone issue: if you have a good signal and still can't send, receive text messages, do and receive incoming, outgoing calls, try to do these: call the service provider and ask for the default network pin, then go to the settings of your phone, call settings, call barring, deactivate all barring
try inserting your sim card to another phone and try to send an sms
turn off your phone, remove battery and sim card and then wait for a few seconds, then put back the sim and battery and turn on the phone then try to send an sms
Apr 19, 2011 | Cell Phones
Nokia 1112 cannot send text messages but can receive
You cannot send messages because the message centre number stored in your mobile may be wrong.
Please enter the correct message centre number. To get the correct message centre number please call your service provider and they will provide you the number.
Menu > Messaging >Options >Settings > Text message >Message centres
Thank You
Apr 04, 2011 | Nokia 1112 Cellular Phone
My mms messages do not send on my curve 8520, they try to send for a long time then show it failed to send, i tried sending to myself and that did not work
This could only be caused by a couple of things. The message center number in the handset may not be correct, which will cause the messages to fail. The other possibility is that the feature is not active on your account with your wireless provider. What you need to do is test a couple of things. See if you can send a text/sms message to yourself, in doing this you can verify that you can not only send, but receive text/sms messages. If you cannot send, or receive text/sms messages, then that verifies that the message/service center number is off, and will need to be corrected. If that works, and you can receive text/sms messages, then your service center number is correct, and you will move to the next troubleshooting step, which is to test your web browser. If you cannot launch the web browser on your handset, then this is an issue, because the MMS service requires that you have both SMS, and web browser service to send a MMS message. If you can access the internet and you have the ability to send/receive text/sms, then you need to call your service provider as the issue may be with their service.
Mar 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
My phone was fine until it started to turn itself off and then back on again without me even touching it. This has currently stopped and now I cannot send any sms. I am able to receive sms and phone calls...
sir, for sending text messages :1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Dec 29, 2010 | Nokia 2630 Cellular Phone
SMS unable to send messages
Just Try either of the following ....
  1. Try checking the SMSC (Message Center Number) number configured on your phone. If the Message Centre number is not configured or wrong then you will not be able to send..but you can receive.
  2. Check... is there any setting called Inbox Setup in Message menu, then Text msg Setup -> Use GPRS -> NO
With Regards,
TPV
Jan 26, 2008 | T-Mobile Wing™ Smartphone
Samsung SGH-G600 Cellular Phone Logo
125 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
