How do I replace the starter in a 1999 Nissan Altima? I am wondering if I can reach it from the top or do I have to go under the car?
    Top Expert:
  • Washing Mach... Master
  • 75,822 Answers
U must go under the car to reach the starter, make sure the battery is diosconnected before you start work
Posted on Nov 16, 2009
How do you replace a starter on a 1999 nissan ultima
this one is a slightly tougher one to replace,because the starter is under the intake manifold and its kinda hard to get the bolt started once you get starter into proper position. you have to pick up the starter into position which is pretty hard from the top and at the same time you have to start the bolt. you will need some extensions (long one) and 14mm socket along with a ratchet oh ya and 12mm wrench or socket to remove cable from alternator. make sure you disconnect battery before you start. good luck.
Sep 19, 2011 | 1999 Nissan Altima
Where is the starter located on a 99 nissan altima, can it be replaced from above with no jack stands?
NO you take the bolts out from the top but it is located underneath the intake manifold and you can not see it from the top. You might need to get it up higher then jack stands to get it out and in.
Jul 02, 2011 | 1999 Nissan Altima
I tried to start my 2001 Nissan Altima today but it would not turn over. It looks like the starter cause my car started with no problem yesturday and Im trying to see how to kick start starter and find...
you can not see the starter on your vehicle from the top. you need to get under the car to see it. its right above the r/h (passenger) side axle, where the axle is going into the trans. this starter is also not that easy to replace for a novice or someone that does not work on cars. good luck.
Dec 25, 2010 | 2001 Nissan Altima
Where is the started located on the 1999 nissan altima? Is it best to remove from top or bottom?
do u mean the starter? if that the case its located at the bottem near the flywheel can only removed through the bottem
Aug 05, 2010 | 1999 Nissan Altima
How to replace starter on 1999 Nissan Altima
You need to Replace starter or have battery checked for proper volts.
Jun 16, 2009 | 1999 Nissan Altima
Nissan altima starter
if you can do a ford you can do a nissan ,just curse in nip instead of anglo saxon
Jan 09, 2009 | 2001 Nissan Altima
Starter
what sort of of engine does your car have in it
Jul 30, 2008 | 1999 Nissan Altima
Replacing a starter for a 1999 Altima
  1. Disconnect battery ground cable.
  2. Disconnect starter wiring from starter.
  3. Remove starter retaining bolts and the starter.
  4. Reverse procedure to install.
the bolts should be on the drivers side.
you will have to crawl underneath the car to do this task
May 15, 2008 | 1999 Nissan Altima
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
