Question about Quasar HQ2051TH Air Conditioner
What is the fault code T5 on a ferolli 38c combi boiler
3 Suggested Answers
  • 9 Answers
SOURCE: fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
Posted on May 04, 2010
SOURCE: Ferolli HE 31C fires up fine, hotwater works, but ...
diverter valve fault most likely. when you call for central heating do you get 3 swiggley lines coming off radiator symbol in the boiler display if you do and not getting central heating then definitely diverter fault
Posted on Oct 02, 2010
What does error code A 01 mean on a ferolli boiler
ignition fault I believe But check you condensation pipe is not frozen
Feb 28, 2018 | Water Heaters
What causes my ferolli f24 to cut out when put on manual heating why does my ferolli f24 combi boiler cut out after putting on manual heating mode?
Possible that the pump is faulty, check to see if it is running, if not check power to pump, if power is okay, and the pump is not running, then it's the pump. look up pdf fault finding f24 for additional help.
Nov 23, 2014 | Water Heaters
What is the reason of code #2 fault on Hobart combi oven?
Hobart will answer that for you! Typically these are water low or thermocouple temp probe fault... I'd check the resetable limit switch for the oven and boiler before I called to be safe/ should be easy to locate in the control panel...
Nov 18, 2014 | Hobart CG10FI-1 - Full Size Steam...
Baxi duo tec e160 code
Fault Code E160 on a Duotec Boiler is a fan fault.
Mine has just gone for the 2nd time! Gas engineer is on his way......
Jan 31, 2012 | Heating & Cooling
Glowworm 24hxi combi boiler fault codes
it's an ignition fault (lockout) failed to light.
cause:
no gas
insufficient gas
incorrect gas valve adjustment
electrode ignition lead defective
electric igniter defective
check air inlet duct
check connections to igniter unit.
most common cause is igniter is defective (looks like a spark plug)
if you can hear a clicking when boiler goes to ignite, then it will be igniter at fault (no spark), check lead going to igniter (for any deterioration, looks like a ht lead). if all ok. change igniter.
hope this helps?
Jan 22, 2012 | Kitchen Ranges
May 20, 2010 | Quasar HQ2051TH Air Conditioner
Fault code ( nocn ) on a ferroli boiler
Apr 25, 2010 | Heating & Cooling
Vaillant Combi boiler
LOOK ON ONE OF THE COVERS 75% OF ALL CODES ARE ON THE INSIDE OF A COVER FOR SERVICE TECHS, NOT MUCH HELP BUT HOPE IT LEADS YOU DOWN THE RIGHT PATH
Jan 23, 2010 | Heating & Cooling
Ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Faulty Worcester boiler
we have a worcester24i rsf boiler installed in our mobile home buy the the water temperature seems locked in at a certain temperatutr any idea how we can change this
Oct 19, 2008 | Combi Centre DX - Mango
Quasar HQ2051TH Air Conditioner Logo
628 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
