Question about Philips SWA2035 - Audio adapter - mini-phone stereo 3.5 mm Headphones
Our tv loses power intermittently but after a few minutes when plug is removed the power is restored. are there known problems with this adaptor or is it the tv
    President:
  • 1,137 Answers
There is a possibility that the jack in the T.V. is wired for mono and the plug you are using is stereo. This means that the stereo plug would short circuit the jack and affect the output stage of the sound. These jacks were used on older T.V.s. Go to your local electronics store and see if they can sell you an adapter to convert the stereo plug to a mono one. Check your manual for the T.V. first to make sure that this is indeed the case. Hope this helps.
Posted on Nov 21, 2009
Reset instructions
If you are trying to power cycle (reset) your TV, then power it off, unplug everything from the back of it, and unplug the TV from the wall for a few minutes. After a few minutes, plug everything back in, and power on the TV. You can also reset any system changes by restoring them back to factory default.
If the problem still exists, then I would recommend setting up repair service.
Oct 16, 2013 | Televison & Video
Hello. I have a lenovo n500. The battery died after i unplugged the adaptor for a few minutes. I plugged the adaptor back in blue light on adaptor and blue light on laptop are on- no power up. I have tried...
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 28, 2013 | Computers & Internet
1997 chev blazer, intermittent problem, loses power on hills, no codes given, rough idle last a few minutes then away you go. this is once in awhile hissy fit. 02 sensors are within tolerance,all tests...
sounds like dirty injectors....Have you tried injector cleaner? Make sure it is the one that removes and not prevents corrosion. I believe STP has it in a silver bottle.
Hopefully someone can back me up on this
Mar 25, 2011 | 1997 Chevrolet Blazer
Acer battery no charge/plugged in "battery is criticically low"
This is a tricky issue, it's either a problem related to the battery or the adaptor.
Try removing the battery and just plug in the adaptor and see if the computer will boot. If it does then there's a problem with the battery and you just need to replace it, if it doesn't then there's a few other things it could be.
The two most likely options is that the adaptor is bad, or the AC port on the computer has become loose. Most of the computers I've repaired that had these symptoms was that the AC port was bad if the battery wasn't. The best way to test this is to plug in the adaptor and just see if it wiggles around a lot, if it's loose then it might not be connecting to the board correctly and will need to be soldered bad on. If it's not loose then the adaptor might be bad, you can test another adaptor on your laptop or that adaptor on someone else's but be carefull, I can't stress this enough, if you're going to switch adaptors you have to make sure that the voltage IS EXACTLY THE SAME and has the same amps, if the voltage is off you can damage the computer, if the amps is off you can damage the adaptor.
If by some fluke it doesn't seem to be the battery, and you tested the adaptor and the AC port doesn't feel loose, then the charging circuit in the laptop might be shot, in which case you'll need a new motherboard.
I think that covers everything, sorry for the wall of text
Mar 01, 2010 | Acer (56.04200.H22) (5604200H22) 200-Watt...
HP Pavilion ze2000 Laptop won't turn on
Have you tried removing the battery and seeing if the laptop will then run?
Jan 18, 2010 | HP Pavilion ze2000 Notebook
Can 15 volt power adaptor be used on an 18volt scanner?
you dont have other choice, how about to buy an multi plug-in adaptor from 3V up to 23V can manage the voltage of your scanner, but if not this 15volts can support your scanner..
Jun 22, 2009 | HP ScanJet 2300C Flatbed Scanner
Lost everything on my laptop as soon as i open it
I dont think you lost everything. Do you see any green power lights and do you hear the normal hard drive and fan sounds when booting up ? If you do and still wont boot up to Windows then reboot and keep tapping on F8 to safe mode and select "last known good configuration". You can also perform system restore.
If you dont hear anything at all, no power and you dont see any green power lights then you may have to plug into another known good power outlet. check that your power connections (including the power adaptor) are secured and if on a strip power off and on. If that doesnt work, try another power adaptor. If those doesnt work
remove the laptop battery and just plug in the adapter.
If youre concern about your personal files you can always take out the hard drive, piggyback it to another hard drive on a known good PC and retrieve the files.
Jan 04, 2009 | Microsoft Windows Vista Ultimate Edition
Tv turns off after a few minutes
I had the same problem with my D61W130. It would turn off and on intermittently. Called a TV repair shop and they said this model was known for it's poor soldering connections on the power board. They came out and took it apart and re-soldered the board. It cost me almost $300 bucks but it seems to have taken care of the problem. It's working great now.
Oct 31, 2008 | RCA D61W130 61" Rear Projection Television
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Television goes off without turning off
your set needs to be repair by a tech you are having a problem in your power suply which is intermittent.either your hrizontal ic is shorting out, or your regulator or your microchip ic.or the diode that couple the collector of the horizontal transistor with the b+ from the fly back.or check for lose solder in the horizontal output or power supply. good luck
Mar 10, 2007 | Toshiba CZ32V51 32" TV
Philips SWA2035 - Audio adapter - mini-phone stereo 3.5 mm Headphones Logo
79 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
