Question about Compaq Evo N610C Notebook
I have a evo n600 it is setup for internet explorer; however, I believe i need a wireless card
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
You are correct. That model of laptop does not have built in wireless.
Posted on Dec 04, 2009
How do i change my nat from type 3 to type 2 with the belkin n600 hd router for ps3
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Jan 11, 2011 | Belkin Play N600 HD Wireless Dual Band...
Cant connect to the internet wirelessly. I get a prompt telling me that the password has been changed.
Uninstall The BELKIN ROUTER MONITOR FROM THE CONTROL PANEL
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Dec 28, 2010 | Belkin Play N600 Wireless Dual Band Router...
Belkin Play N600. Acer Vista laptop. Wifi only, laptop wifi connects then disconnects. With ethernet connected the wifi and ethernet shows connected, when unplugged, the wifi will disconnect also.
Regards
TOM
Dec 24, 2010 | Belkin Play N600 Wireless Dual Band Router...
I have a N600 wireless dual band gigabit router and I am trying to find the right software. The software I have is labeled super-g - wireless router WGT624. Is this the right software for this router?
Actually, there is _NO_ need to use any software at all to configure the router.
Connect an Ethernet cable between the one of the LAN ports on the router to the network-port on your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway.............192.168.xxx.yyy
Start Internet Explorer
Enter: http://192.168.xxx.yyy
to access the web-server "inside" the router.
Login to the router.
Click to run the "Setup Wizard" to configure the router.
Click to run the "Wireless Networking Setup Wizard" to configure the wireless interface.
Now, you can disconnect the Ethernet cable, and "view available wireless networks",
to view the network that you just defined.
Dec 14, 2010 | Computers & Internet
Internet connection not working right compaq evo n1020v
Hello
First you will need to have the install disc for your card.Install driversoftware from cd or dvd, following directions.Once installed you should see a new hardware device has been found notification.
Next you will need to configure your card with the routers wep key or wireless security key.I am assuming wireless is activated on your router.Should see a light on the router lit under wireless,or a symbol.
1 start pc then start internet explorer.
2 Type in the top bar of ie 198.162.1.1 or 198.162.1.0 hit enter.
3 This should bring you to the routers home page.usaername=admin password=password or admin
4 Find your wireless tab or settings page looking for security area.
5 Find your wep or wireless security code,write this down.
6 Log off of router.
7 Go into network cards configuration program and put this wep code into the area provided.
8 Software may have found it automaticly, it just needs this code.
If you cant connect to router at step one use a ethernet cable from your pc to the router to log on.
Hope this helps.
Jan 23, 2010 | Compaq Evo N1020V Notebook
Compaq evo n800 laptop built-in wireless internet
right click "my computer", left click properties, select "Device Manager" Expand anything to do with "Network Adapters" and make sure there are no problems / exclamation marks / unknown devices.
If there are, look for your wireless driver on..
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=compaq+evo+n800&submit=Go+%C2%BB
depending on your model. if this doesn't work go to www.hp.co.uk and download the driver then install it.
If you can't detect any wireless networks, make sure your wireless card is activated - I believe this involves holding down FN (bottom left of keyboard) while then pressing F2 key at top. after this try try to search for wirless access points points.
Good Luck,
Cheers,
Colin
Mar 18, 2009 | HP Compaq Evo n800c Notebook
Compaq Evo N610C Notebook Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
