Question about Agfa Cyber-shot DSC-W150 Digital Camera
It turns on then turns off right away - Agfa Cyber-shot DSC-W150 Digital Camera
Dryer starts but turns off right away.
best to call a service man might just be a lint problem but also could cause house fire .
Feb 20, 2015 | LG Dryers
What kind of noise will you hear with bad right wheel bearing? It sounds like a whirl behind radio and gets louder with increased speed over 35mph.
the noise should change or go away when you turn the wheel to the right or left. if it does it sounds like you have a bad wheel bearing. Typically if you turn to the left and it gets louder its the right side if you turn to the right and it gets louder its the left side. Or if you turn to the right and it goes away its the right side and if it goes away when turning to the left it is the left side.
Another thing you can do is safely jack up the front of the vehicle. With the transmission in neutral rotate each wheel by hand while holding onto the strut spring with your other hand. You should be able to feel the noise you hear in the strut spring if it is the bearing.
Nov 22, 2010 | 2001 Buick LeSabre
2005 Toyota Camry is making a loud scraping sound after driving 15 mins...What could be causing the noise? I took it in to Toyota and Firestone and they couldn't find anything...
Take the car out on a quiet parking lot(no traffic) get it up to speed and when the noise is occuring turn the car to the right and to the left...did the noise go away???
I think on one of those turns it did...if it went away on the left turn the left front wheel bearing/hub assembly is bad and needs replacement, if it went away on the right turn the right side hub/bearing needs replacement. Hope that helps!!
Aug 26, 2010 | Toyota Camry Cars & Trucks
Noise coming from the front end while your on the highway then goes away when you turn to the right
More then likely you have a bad front hub bearing assembly.Noise goes away when turn right less pressure on right wheel bad right front bearing.
Jan 19, 2010 | 2001 Mazda Tribute
Ti84 Plus Turns on, and turns off right away.
I had the same problem like yours. First, I reset the RAM and then it no longer turned off right away; but it responded extremely slowly. Second, I tried to install the new OS for it, but unsuccessful until I blowed really hard several times into the round connector. After that, the cursor started blinking. Finally, I downloaded the new OS into it and hoped that the problem never happen again.
You go to http://education.ti.com and follow their procedures to reset the RAM.
Sep 17, 2009 | Texas Instruments TI-84 Plus Silver...
Problems when starts..
Turn your key on for 10 seconds but do not start the engine. That will give the fuel pump time to built pressure. After the 10 seconds try starting the engine. If it starts right away you may have a weak pump or dirty filter.
Oct 02, 2008 | 1999 Chevrolet Cavalier
Agfa Cyber-shot DSC-W150  Digital Camera Logo
22 people viewed this question
Top Agfa Cameras Experts
CHIVOIU...
CHIVOIU...
Larry Stiles
Larry Stiles
Are you an Agfa Camera Expert? Answer questions, earn points and help others
