Question about Leviton 604-6633PW Decora Slide Dimmer 3-Way Switch
Convert 3-way to single pole
I wish to eliminate a three-way connection and use one switch for the original light, the other will control a ceiling fan/light eventually. How do I make this type of change? Thanks,
Gene
  • chris poole May 11, 2010
    is the power(wire from the breaker) an the switchleg(wire going to the light) in the same box or is the power on one en and the switchleg on the other.
electrodynam
  • 35 Answers
SOURCE: Revised question for three rocker switch.
Posted on May 22, 2009
  • 76 Answers
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
Posted on Jun 27, 2009
  • 12104 Answers
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Posted on Feb 22, 2010
  • 202 Answers
SOURCE: I have a leviton 5226 single pole switch with
It's the same as you wire any single pole switch.
Posted on Mar 15, 2010
al_kupchella
  • 843 Answers
SOURCE: Three way switch does not work properly
Very interesting problem! But easy to fix. It's not a defective switch, just a minor wiring error, which would be very hard to solve via back and forth text. So, instead of trying to figure out exactly which wires and terminals to swap at the new switch, it would be much easier to simply swap the light and fan wires at the ceiling fixture, I hope this is helpful. Good luck, Al Kupchella
Posted on May 17, 2010
Separate 1 switch 3 lights
You need separate wire going to each light.
Here are diagrams:
2 single pole switches, before you started to replace
http://waterheatertimer.org/images/2-single-pole-switches.jpg
Single pole and 3 pole to control each light separately: must identify black wire to each light. If each light does not have separate black wire inside the switch box, then it is not possible.
http://waterheatertimer.org/images/single-pole-and-3-pole.jpg
Add a comment
Jul 05, 2013 | Electrical Supplies
Replacing a triple single pole (1980's) with a
DISCLAIMER:Attempting to work on house electrical systems without proper training is DANGEROUS and you stand the risk of dying.
The Cooper 7729w is a three pole single throw switch with a common (connected) hot wire that supplies it. What you had before was two separate single pole single throw switches and one single pole double throw switch that is used as a three way. The short answer is NO that replacement will not work UNLESS you don't want the other switch on the other side of the room to work.
Personally, I think that if you really need to ask this question you need to seek the advice of a professional electrician.
Dec 18, 2012 | Electrical Supplies
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
I turned power off to wire a ceiling fan, when I reset the breakers the Dimmer witched do not work.
Did you remove the dimmer switch or alter the wiring whilst putting the ceiling fan control in the wall? If so you have obviously wired it back up the incorrect way. How many original wires were at the light/dimmer switch. Will need to know colours etc?
Feb 13, 2011 | Lutron Ceana Single Pole 277V Switch,...
Replace a hampton bay ceiling fan light switch
buy hampton bay single pole fan switch for light pull three screws out pull cover off remove old switch replace with new switch
Jan 30, 2011 | Hampton Bay 24002 Ceiling Fan
MY HUNTER ORIGINAL RUNS THRU AN ORDINARY WALL SWITCH. IT HAS HI AND LO SPEEDS ON THE HOUSING, BUT EVEN LO SPEED IS A BIT TOO FAST AT TIMES... HOW CAN I CONTROL THE SPEED THRU FULL RANGE... A RHEOSTAT...
Jim,
You have a special fan there. Hunter Originals are my specialty.
There are two ways to accomplish a slower speed with this fan.
1. A wall variable speed control, solid state, rated for 3 or more amps, regular fan controls will not work as your fan draws 2.5amps on high, not even new ones that are labeled for the Original.
2. Retrofit the fan to make it a three speed. If you're good with wiring, it's really simple. What you need is, a standard 3 speed pull chain switch, not a double pole one like cheaper/new fans have that use capacitor speed control, we are using cap. speed control, but not the same way they do. So you want an "SP3T" switch. You also need an 9 10 or 11 or 12 MFD capacitor (depending on how fast you want your low to be 8 is 20rpm, 11 is 75 approximately). You will remove the switch cap to your fan, and you will find your switch has a black, blue and red wire connected to it. Remove all wires, attach the black to L on your new switch, attach blue to 1, then you need 2 extra pieces of wire. Stick one wire in 2 and the second wire in 3. Now, get your capacitor and hook one side of it to the red wire and position 2, then hook the other side to the wire you put in position three.
Remember to get the Single pole switch for non capacitor speed control fans, if you get the double pole, both winding sets in your fan will be activated, which will draw double current and burn your motor out.
2speedorignial.png?t=1296263478
Also, are you aware that your fan uses oil (like an engine) ? and is not permanently lubricated?
Jan 08, 2011 | Hunter Ceiling Fan Control Switch
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
Installing a combination switch
The three way will have more connections, whereas the Single Pole, should only have a few contacts the three way will have more.
May 27, 2010 | Leviton 002-1754-W Dual Rocker Switches
May 16, 2010 | Pass & Seymour / Legrand 1595-2SWT...
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
Leviton 604-6633PW Decora Slide Dimmer 3-Way Switch Logo
870 people viewed this question
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Steve
Hippy_dd
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
