Question about LG KG800 Cellular Phone
HELLLPPPPP! i dont know how to save on th "contents bank"! in the help it doent say! i dont know if im even conected!!!
    Brigadier General:
  • 7,752 Answers
Contact your mobile service provider
Posted on Apr 08, 2008
6ya staff
SOURCE:
Need to get to my starter
Starters are assets of gears box and what model your car? Then i will send these photos
Dec 15, 2013 | Cars & Trucks
4 th spark plug is not firing, i have changed ht coil and spark plug also checked connecting wire but still problem exsist.
hi trace this wire back to ecu, and check her you are getting a signal, (tip) loosly run a wire from her to the coil, and check if this solves the problem, this will eliminate any wiring problem, i trust you have conected the coil up to a diffrent feed and checked it works on 1 that you know works? process of elimenation, the next step would be a dealer diagnostic plug in which may save you money in the long run, they dont have to fix it just tell you the problem, hope this helps, paul
Dec 30, 2010 | 2005 Suzuki GSX 1300 R Hayabusa
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
Bought fable2, knothole island DLC and my save wont load.
Was this purchased while connect to your friends connection? if so then the problems is that it was purchased with his connection and not your own
Oct 01, 2009 | Microsoft Fable 2 for Xbox 360
Cant get my playstation 3 to work
go into the set up menu and re-activate the HDMI output, you will need to do this while it is hooked up with a diff conection
Jul 08, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I dont know how to install my D-link 524 router.i need wireless
http://www.it.hiof.no/datakom/lab/di514_QIG_103.pdf
go for this web site you go the your anwers
May 23, 2009 | D-Link DI 514 Wireless Router (DI-514)
Why is my modem not recognised by vista ???
HI
Please confirm that your Dlink Di 524 firmware is upgraded. With Vista the firmware update resolves the issue.
http://support.dlink.com/emulators/di524/tools_firmw.html
use this to update teh firmware. its shows instructions on how to to do that.
let me know if you need more help.
thank you
rakesh
Dell Laptop Expert
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Acquring network conections
do you know who set up your router im guessing its not you as you dont have your wep key if you do have it its easy if you dont you need to connect to your router with a cable to get the wep key once done you mat need to set up your ip address on your laptop it should be 192.168.0.2 with a sub mask of 255.255.255.0 and a default gateway of 192.168.0.1 and a primary dns server of 192.168.0.1
any more help just ask
Oct 29, 2007 | NetGear DG834G Router
I cant transfer music and photos to my phone
go to "settings" then "connectivity" press "modem" say yes BUT DONT CLOSE THE PHONE. then connect it to the PC and run contents back and connect :).
Aug 22, 2007 | LG KG800 Cellular Phone
LG KG800 Cellular Phone Logo
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
