Question about Sony Xplod XM-554ZR Car Audio Amplifier
I cant figure out wh y my sony xplod 500w amp isnt working... i have everything connected but it still isnt wotking
  • colin butcher May 11, 2010
    So you have all wiring correct, you have a power light on, the amp is earthed to the chassis,you have a remote lead attached to the amp from the headunit, all fuses are ok, have you checked the adjustment dials on the amp .
  • Perry Babin May 11, 2010
    Is the power LED lighting up?
    Novelist:
  • 92 Answers
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT POWERS UP FINE,THEN PROCEED TO CONNECT THE SPEAKERS FIRST AND SEE IF IT STILL POWERS UP FINE, THEN MOVE ON TO RECONNECT THE RCA INPUTS. AT THIS POINT YOU SHOULD HEAR MUSIC, IF NOT AND THE AMPLIFIER IS POWERED UP AND NOT GOING INTO PROTECTION, THEN YOU MAY HAVE AN INPUT PROBLEM FROM THE RADIO. IF THE AMPLIFIER FAILS TO POWER UP AT ALL AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. YOU CAN CHECK THE VOLTAGE TO THE REMOTE TERMINAL TO MAKE SURE THAT IT ABOVE 11 VOLTS, AS SOMETIMES A FAULTY REMOTE OUTPUT FROM THE RADIO CAN SOMETIME FAIL TO TURN AN AMPLIFIER ON. REMEMBER IN ANY CASE YOU ONLY HAVE AN AMPLIFIER, AN INPUT AND A SPEAKER. USE THIS PROCESS TO HELP YOU DETERMINE WHERE THE PROBLEM IS LOCATED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Posted on Jan 06, 2010
No sound to the subs
Possible solution: Check to make sure your ground connection is connected to metal that is NOT covered in paint. This is not a solid connection and can ruin your amp over time. Simply scrap away the paint and re-connect. This was a problem i ran into recently.
Jul 27, 2009 | Sony XPlod CD Player w/MP3 Playback...
My sony sub isnt working, i checked the wires
do you have a power on signal wire hooked up?
Jun 08, 2009 | Sony Xplod (P589) Car Subwoofer
The power protection kicks in when I turn up my radio volume
ground wire connection or possibly amp is turned up to high when an amp is turned up all the way it starts pushin dc voltage also it could burn out the internal battery check all connections and settings after that make sure subs arent begining to blow a sub that starts to blow kicks of the amp hope this helps
May 21, 2009 | Sony Xplod 500W Bridgeable Multichannel...
Bought amp and cant get it to work
Do you have the remote wire connected to the head unit?
You can also use the power antenna connection from the head unit to provide the remote on signal to the amp.
Apr 12, 2009 | Sony Car Audio & Video
No sound from my amp
the red light usally means its over heating and turns off the amp as a protection
Mar 26, 2009 | Sony Xplod 500W Bridgeable Multichannel...
I have an older red sony xplod 500w 4ch amp. the power/protection light is glowing red. what does that mean and how do i fix it? I have no sound.
The protection light comes on if the amp overheats or if the speaker outputs are shorted.
Turn everything off and check all of your speaker wires for shorts. When you locate and repair the short, the protection light should go out and your amp will work normally again.
Hope this helps!
Mar 26, 2009 | Car Audio & Video
the kight is red because it isnt wired properly, try connecting a thicker ground wire then double check the fuse in amp plus in the power supply cable
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Mar 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplod 500w 4/3 channel
If the speaker is a 4 ohm DVC (two 4 ohm coils), you can't wire it to get a single 4 ohm load. Try connecting one coil to each of the two rear channels. It may not be as loud but the amp should operate without going into protection.
If the two 4 ohm coils are in parallel, the amp is driving a 2 ohm mono load. That's probably why it's shutting down.
Apr 25, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
171 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
