Question about Car Audio & Video
I have a 2003 chevy s10 extreme speedometer shows 1oomph standing
I have a 2003 chevy s10 extreme i just removed my old coolair intake and replaced it with the vortec intake but directly after my speedometer showed i was pegged at 100 mph while i was standing still
justuscc
  • 360 Answers
SOURCE: Flashes "D4" and speedometer shows 0 MPH while driving
this sounds like a Transmission Speed Sensor. ive done about 20 of them , common on hondas
Posted on Sep 30, 2008
  • 341 Answers
SOURCE: 94 1500 speedometer
bad speed senor on trans
Posted on Oct 19, 2008
  • 140 Answers
SOURCE: Isuzu Hombre 4.3 (Chevy S10) 1997 won't start
Definitely check for spark next. let me know what you find.
Posted on Dec 30, 2008
  • 11 Answers
SOURCE: JVC KD-G140 Chevy s10 problem
Your headunit is getting constant power (yellow wire). You most likely have no switched power (acc red wire). You can be certain by testing the red wire w/ a 12 volt test light when your ignition is on. If there is no power to this wire then you probably have a blown fuse. The radio fuse should be a 10amp fuse located in the drivers kick panel.
Posted on May 28, 2009
  • 3741 Answers
SOURCE: My oil presure is pegged to the max on my 2003 tahoe...
Oil pressure sensor is located in the valley of engine behind intake.at back of engine you can get it out with a thin walled oil sender socket. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Feb 27, 2010
I need a vacuum hose diagram for 2000 Chevy S10 2.2 from the top of the Intake Manifold
https://www.bing.com/images/search?q=i+need+a+vacuum+hose+diagram+for+2000+chevy+s10+2.2+from+the+top+of+the+intake+manifold&qpvt=i+need+a+vacuum+hose+diagram+for+2000+chevy+s10+2.2+from+the+top+of+the+intake+manifold
Sep 04, 2017 | Cars & Trucks
How can I remove gear-to-gear timing cam?
images for How to remove a gear to gear timing cam ...
DIY Timing Chain and Gears Removal - YouTube
? 6:31
https://www.youtube.com/watch?v=eMXO1bvUCMs
Dec 30, 2012 - Uploaded by Bullshitkorner
The most important part when doing timing gears on a engine is ... Doing this inside the engine bay will be a bit of a pain in the axx but it is doable for sure. ... How to build a Chevy 383 Part 3: How To Install a Cam & Timing ...
Head removal & replacement, Timing Chain & gears also ...
? 3:28
https://www.youtube.com/watch?v=CnXtwR1N0Og
Apr 28, 2012 - Uploaded by No1hmfic Gibson
Head removal & replacement, Timing Chain & gears also, 97 Chevy S10 2.2 ... replacing the head gasket in a chevy cavilier 2.2 liter 4 cylinder - Duration: 9:38. ... 98 S10 Vortec V6 4.3 Intake Gasket Replacement Part 1 of 5 ...
Chevy S 10 2.2 L Engine Timing Chain Replacement Guide ...
? 7:30
https://www.youtube.com/watch?v=8nX5HARPSF4
Feb 03, 2016 | 1998 Chevrolet S-10 Pickup
I have a 2003 Chevy blazer with a 4.3 vortec motor it has a small leaking head gasket how long can I drive it until I have the money to fix it.
Troubleshooting a Blown Head Gasket (GM 4.3L, 5.0L, 5.7L)
troubleshootmyvehicle.com > GM > 4.3L, 5.0L, 5.7L
Mar 28, 2011 - There are so many ways to test for a blown head gasket on your 4.3L, 5.0L, 5.7L GM van (or mini-van, pick up, SUV) that it can get confusing.
Chevy Blazer Coolant Leak (Intake Manifold) - YouTube
? 4:33
https://www.youtube.com/watch?v=SC4VXdt5wiE
Oct 9, 2013 - Uploaded by eyetotheworld
I have localized a coolant leak on my 2003 Chevy Blazer to thegasket of the intake ... Turns out that this is common among this particular engine both in the v6 & v8 sizes. ... The guy has been generous to detail his projects. ... 98 S10 Vortec V6 4.3 IntakeGasket Replacement Part 1 of 5 - Duration: 18:17. by ...
Chevy 4.3l v6 oil leak issue 2001 Xtreme Blazer - YouTube
? 6:11
https://www.youtube.com/watch?v=Y8Ogd5voIYs
Nov 12, 2011 - Uploaded by smiatacz
This darn little engine just keeps going. ... I have a 2003 chevy blazer and the oil cooler line from the oil filter to ... I have a 95 Chevy s10 v6 vortec 2wd that is slightly dripping oil out of agasket ... I'm having same problem 2001 Chevy Blazer 4x4 (not xtreme) not sure if those same bolts are missing on mine.
Dec 28, 2015 | Cars & Trucks
Where is thermostat located 4.3 liter chevy s10, 2003
The thermostat is located inside the steel thermostat housing, which is located on the front of the engine right in front of the throttle body housing and halfway between the alternator and a/c compressor. Remove the air intake assembly and remove the front bracket connected to the front two bolts of the throttle body. Then remove the two main bolts of the thermo housing. Lift up the thermo housing and you will see the thermostat sitting there.
Sep 30, 2015 | Cars & Trucks
I have a 02 Chevy s10 blazer extreme 4.3 can't find wire or plug that plugs into temperature sensor on intake were should I look for it or were should it coming from?
Are you talking about the IAT sensor? It is usually located in the plastic flex pipe from the airbox to the intake. Sometimes in the airbox itself.
Jun 12, 2015 | Chevrolet S 10 Cars & Trucks
Right rear wheel locks up on a 2003 chevy s10 extreme
This problem ususally indicates a brake that is out of adjustment, it tends to be very common also for a vehicle with leaking wheel cylinders on a vehicle with rear drum brakes,
Mar 17, 2010 | 2003 Chevrolet S-10
Replace 2003 Chevy S10 V6 Exhaust Manifold
On the studs on the bottom be sure to soak them with a good penitrating oil over night. Then on the removal if you feel like they are binding work them back and forth. They may break but you should get new studs with the new one. On the head side just be carefull, if you break a bolt off in the head you have real problems then. Not really complex just use your head and don't be to forcefull.
Good Luck
May 16, 2009 | 2003 Chevrolet S-10
Car Audio & Video Logo
110 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
