Question about Bosch Classixx WFC 2465 Front Load Washer
THERE IS POWER TO MY BOSCH 1200 W/MACHINE AND IT TAKES IN WATER BUT NO DRUM ROTATION. CAN MANUALLY MOVE TO DRAIN AND DRAINAGE IS FINE, BUT IF I SET TO SPIN IT DOES NOT SPIN. IT TICKS DOWN THE MINUTES AS IF GOING THROUGH A NORMAL WASH CYCLE BUT FAILS TO ROTATE?
  • 491 Answers
IT SOUNDS LIKE THE DRIVE BELT HAS BROKE, IF YOU CAN BUT FIRST MAKE SURE THE POWER IS OFF REMOVE THE PANNEL AND LOCATE THE DRIVE BELT TAKE THE BELT TO A PLUMMERS SUPPLY STORE FOR A REPLACEMENT AS IT WOULD HAVE THE PART CODE ON IT THEN REPLACE THE BELT AND YOUR MACHINE SHOULD VWOOK FINE , GIVE IT A GO YOU CAN LEARN .
Posted on Nov 16, 2009
  • 11,896 Answers
Sounds like a selector switch problem. It is common. Do make sure the belt is not off the pulleys. You can check power to motor with a voltmeter. Can you manually spin the tub with your hand or is it frozen up?
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Thanks. My classixx 1000 does exactly the same. My partner will do the "operation" tomorrow. I will let you know the result!
Posted on May 25, 2010
Bosch exxcel f18 error. Machine runs cycle but will not drain water. Have emptied and unblocked pump on front and checked drainage hose.
according to what i find on google, it's a drainage fault, drain manually and check filter...ALSO CHECK OUTLET PIPES FOR ANYTHING BLOCKED IN IT
Dec 29, 2013 | Kenmore Washing Machines
Have bosch dishwasher water will not drain out what should we do?
hello,
what this means is that there is a blockage from the drain what you need to do to fix up the problem is to bale out all the water from the drum then you will fine the cloth or the dirt that have block the drainage remove it then the problem of the block drainage is solve.
please make sure that all forms of power supply is disconnected from the washer when doing this
thank you and thanks for using fixya.
Jun 11, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch WFMC 3200UC can't rotate the drum
that test indicates a faulty speed sensor or wiring harness.
Jan 23, 2010 | Bosch WFMC 3200 Front Load Washer
My Bosch WFK 2401 keeps giving me the 03 error message, the pump looks fine when I drain it manually (which takes 1/2 and hour!, now I don't bother draining it completely, I just drain a bit of water from...
hi there,
the 03 error message is the machine not sensing the water level. since you can drain using the pump manually, check the water level switch, as it may be faulty.
Oct 05, 2008 | Bosch Washing Machines
Bosch Running a LONG LONG Time and Watering Remaining
You could try running the machine with the drain hose leading to a large bucket. If it works OK in this situation then the blockage will be most likely where the drain hose joins the house drainage system - often at a junction under the kitchen sink. With the drain hose disconnected you should be able to see the blockage and clear it with a suitable pointy tool.
Let me know if this sorts it. Thanks, D.
Jul 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
My bosch classixx 1200 express
Close the door and turn the dial to drain
Jan 11, 2018 | Bosch Classixx WFC 2465 Front Load Washer
Bosch wff 2000 washing machine - won't spin/drain
How did you solve this problem. I have the same problem. Kiran
Mar 09, 2008 | Washing Machines
Bosch Classixx WFC 2465 Front Load Washer Logo
433 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
