Question about Nikon FE 35mm SLR Camera
Film rewind crank came off, rewind shaft fell into camera body. a) Can I get camera open? b) Is reassembling pieces fairly easy? Thank you, Paul LaFond
  • pauljlafond Dec 07, 2009
    Isn't each side equal distance away from the center of the camera? It doesn't note what to do with the hook. I actually have a dentist's cleaning tool, which seems ideal, but it doesn't say how to unlatch the door. If I can open the door I can probably take it from there . . . .
  • pauljlafond Dec 08, 2009
    I got it! I downloaded schematics from Nikon, determined the configuration of the latch, my tool was small enough to pick the latch and then I wrestled with the assembly, assembled and unassembled it a few times and finally got it right! That was fun but I don't want to have to do it again!
    Thank you,
    Paul
  • 667 Answers
Yes, and yes. A small hook is needed, a small crochet hook will work. The latch is on the side farthest away from the center of the camera. You are pulling up to free the door latch. The rewind knob is tricky, but possible. Keep the door open while re-assembling as the center shaft will be loose till you get the knob on. The handle and pin are easy, assemble them 1st. Hold the center shaft, put the coil spring in, then the washer and finally the spring plate. Guide the handle/knob assembly onto the shaft with the parts. It is tricky to hold it all in place, but is possible.
Posted on Dec 07, 2009
Testimonial: "Comments weren't real specific but helped me repair the issue. I was still "on my own" quite a bit in figuring things out,but this help got me thru it"
  • Kevin Pettit
    Kevin Pettit Dec 07, 2009
    Use the hole where the rewind shaft should be. The plate that latches the door it L shaped. It runs along the side of the camera and then extends into the rewind area.
  • Kevin Pettit
    Kevin Pettit Dec 08, 2009
    Excellent, at least you had all the pieces. Replacements are scarce.
How do you replace the rewind shaft of a pentax k1000 without causing any damage?
Open the camera film cover back.
Stick a flat blade screwdriver between the silver film sprocket, then turn the Film Rewind Crank out.
atdlee@netzero.com
Jun 25, 2014 | Photography
I have recently just took a roll of film out of my camera. It is a Asahi pentax K1000. I opened up the back panel to take out my film and the panel closed without any new film being put in. Now the rewind...
Try holding the camera upside down to see if it slides back into place. If that doesn't work, imagine that there is a film in there and wind it back like you would to take the film out, this may put the shaft back into place? Good luck.
Jun 24, 2014 | Photography
Rewind crank is loose on my Minolta XG 1 Film SLR
There is a spring in the bottom of the rewind knob that holds the crank, and it sounds like it has dislodged or the plastic rewind knob is cracked (try small amount of super glue for this). You can rewind the knob off the shaft (open the film door and put something in the rewind fork to keep the shaft from moving) and then turn the rewind knob opposite the direction of the arrow (if the arrow says turn clockwise, then turn counter clockwise). This will allow you to remove the rewind knob assembly and check it for damage, etc. Also, there is a small shaft at the end of the crank. Make sure it is not bent.
May 16, 2014 | Minolta Photography
How can you rewind the film
Lift up the rewind crank. Press the film rewind button on the bottom of the camera and turn the crank clockwise. Rewind until the tension on the crank lessens, indicating that the film leader has been released from the take-up spool. Pull up on the film rewind crank and the back will open.
Dec 03, 2010 | Pentax ME Super 35mm SLR Camera
How do i open the back cover , and what is the rewind crank ?
You open the back by pulling upwards on the rewind crank. The rewind crank is on the top of the camera on the left (as you look through the viewfinder) in the center of the knob that sets the film speed. The crank is folded into the knob. DON'T open the back until you have rewound the film. You will have to press a button on the bottom of the camera to release the film before you can rewind.
It will be a lot easier if you can get an experienced person to show you the first time.
Nov 21, 2010 | Minolta XG-A 35mm SLR Camera
My Canon AE-1 rewind crank came off while rewinding the film. can it be fixed?
Yes. I am not sure that you can do it yourself. It depends how handy you are with fiddly mechanical things. Any camera shop ought to be able to put it right.
I believe that you have simply unscrewed the crank by winding it in the wrong direction. It will screw back on, but you will need to open the camera to get hold of the internal part that it screws on to (the bit that fits into the film canister). This will need to be pushed upwards in its socket to allow you to get the crank started on the threads on the top of the shaft, and you will need to put the end of a screwdriver or something through the slot to get leverage when you come to tightening the crank the last bit.
If you heven't rewound the film yet, then open the camera in complete dark and rewind the film into the canister by hand. I usually do this in a darkened room under a bed quilt.
Nov 03, 2010 | Canon EOS-AE-1 35mm SLR Camera
Pentex k1000 rewind knob unscrewed, shaft fell inside camera
first make a small hook on the end of a straightened paper clip. insert the hook and pull up rotating the hook as you pull up. being careful not to bend the spring near the hole. once the back door is opened check the rewind shaft, there should be a beveled edge on the collar of the shaft. rotate the shaft while pushing up. if no beveled edge on the shaft use the paper clip to push the spring out of the way while inserting the shaft. if it still will not return file a bevel on the collar of the shaft. I am assuming there is no film in the camera as the canister will prevent the shaft from falling in.
Jan 29, 2010 | Pentax K1000 35mm SLR Camera
Canon AE-1 Crank came off and the rewind shaft is inside
If the crank is missing a very strong tool is needed to hook into the area inside to open the film door. Use a tiny screw driver for eye glasses for this fix. Insert the tool and apply pressure to it so it will not come out, then pull it upward as you did whe the crank was there before. These partts are on Ebay every day too for sale
Dec 22, 2009 | Canon EOS-AE-1 35mm SLR Camera
The nob that rewinds the film fell off my camera, and i unfortunately could not find it. Is there anyway to get the film out of the camera before I get a replacement piece?
yes, after dark find the darkest room or closet you can find, make sure no light is coming in around the door. pull up on the rewind shaft to open the back door. remove the film and rewind it into the canister by hand. turning to the right.
Oct 21, 2009 | Pentax K1000 35mm SLR Camera
Nikon FE 35mm SLR Camera Logo
1,047 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
