Question about Samsung HCM4216W 42" Rear Projection Television
Samsung hcm4216w when i try to turn on the tv nothing happens except the red light by (timer) flashes and it sounds like it try's to turn on, nothing ever happens the red light stops flashing and no sound or picture??? any idea's??
  • 2 more comments
  • tandacarlson Jan 21, 2008
    Thanks for the advice. I did replace the entire convergence board and now I have a pink vertical line in the middle of my screen. Any idea's???
  • Eortiz Apr 14, 2008
    When i try to turn the TV on, All I see is a blinking red light by the timing switch
  • Anonymous Apr 23, 2008
    my tv
  • Eortiz May 11, 2010
    In my SAMSUNG HCM4216W, Where is the pico fuse located at, and where can I get the convergence board , stk392-040 ics and how much should expect to pay for each one. also a pico fuse (3.5a) Thank you very much.
The most common problem for those symptoms are convergence amps. That unit takes two stk392-040 Sanyo Ics and will most likely require that several low ohm resistors (3.9 ohm-2w) be tested and possibly replaced.. There is one last thing also, a pico fuse at Fd102 (3.5a) that sometimes opens and would need to be replaced..
The convergence board in these is easily removed, so an in-house service call could be done...
Hope this helps
Posted on Jan 19, 2008
when the timer light is turn ON, tv is telling you that lamp will be going out soon, is basically a hour meter, it just reach the limit of hours that tv haves program of use for a lamp and that you can reseted by:
1.- taking the lamp out nad in again, that way tv will detect there is a new lamp. If not.
2.- folow the instructions:
Jun 25, 2009 | Televison & Video
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
Timer Light.
according to the book hcm4216w says ti will blink 10 times when turned on then then iluminate when on
Jul 20, 2008 | Samsung HCM4216W 42" Rear Projection...
Red blinking light
It's most likely convergence -- the small board up and to the right inside the back of the TV, which has two large amp Ic's attached to it..
Unplug the +/- 20v line on the fron left corner of that board (red in color) and then try and power on the set... If the set comes on the board needs to be repaired and it's an easy unplug and two screws that mount it inside.
Premium Technologies
PO Box 442
LOng Beach, WA. 98631
Apr 18, 2008 | Samsung HCM4216W 42" Rear Projection...
View timer only lights
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
TV turns off by itself (not timer issue)
Probable bad green CRT. Also, look for coolant leak from
CRT onto PCB.......T
Oct 24, 2007 | Samsung HCM4216W 42" Rear Projection...
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HCM4216W 42" Rear Projection Television Logo
181 people viewed this question
Jerry Greenberg
Jerry Greenberg
