Question about Toshiba 50H72 50" Rear Projection Television
Toshiba 56PW8 rear projection - lost sound and picture after powercut
We were watching the tv during a period of irregular power supply (during a storm). Seemed ok then suddenly went off. Now when we turn it on as normal, we hear the usual 'click', but have no picture, no sound, nothing. The front red light comes on as normal, but strangley it then altrernates between red and green every few minutes.
Manual says green light is something to do with the timer.
  • Anonymous Mar 08, 2008
    no sound , sound was working fine, where is the power deflection board , is it behing the right speaker, and the white covers are they for the fuses
  • 934 Answers
The convergence amps in those units consist of two Sanyo STK392-110 Ic's that get hot enough to fry eggs.. If your storm flexed voltages enough it could have easily shorted the amps and/or take either of two pico fuses in the 24v supply line to the amps... If you're not too tech savy this is one for a reliable shop and not and expensive fix. Two Sanyo Ics and a couple pico fuses should be more than $50.00 dollars and a couple hours of labor to put them in... While they're at it have them check the caps in the hyper module and for any ring cracks in the deflection circuit...
Posted on Feb 03, 2008
I have the Toshiba 61A61 TV. I am not sure what exactly happened, but when the TV was on, suddenly the picuter went black. I still receive the normal sound, but can't get any picture (totally black). I...
Check all connections?Unplug,replug the cable box about an hour later let it upgrade it software.The projection lamp has not been replaced in this tv the last 1 1/2 or 2 years?The tv been on and watches at lest 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
Sep 03, 2010 | Toshiba 61A61 61" Rear Projection...
I have a rear projection Toshiba 57" theatrewide - assembly date 2003, that during a storm took a hit. No power, no click, tested the fuse from the outside and it was good. Also tried to manually reset...
Working from the point of view of the power cord, the first module that is generally encountered is the power supply. Search for a service manual, sometimes user manuals will also have a schematic, to help you troubleshoot the power supply section. If you are lucky, the power supply board will have the outputs stenciled on the PCB itself, making the task of verifying output voltages easier.
Aug 17, 2010 | Toshiba 57H81 57" Rear Projection...
65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
Sep 17, 2009 | Toshiba 55H70 55" Rear Projection...
Have a Toshiba 42H82 rear projection TV
Sounds like a power supply problem. You will need your tech again.
Nov 13, 2008 | Toshiba 42H82 42" Rear Projection...
Sony wega 42inch
Power surge has damaged power supply, have serviced
Apr 22, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Toshiba TN43V71 43 in rear projection
Hello WendyOreo,
It sounds like your switching power supply or you High Voltage power supply has malfunctioned. These sections control all power to the TV and can produce the situation you are describing. If you do not have a background in electronics, I would suggest that you have a TV repairperson come over and check your TV out.
I say this because there are voltages in a TV set that can kill, so caution is needed.
I hope this helps
Thank you,
Oct 17, 2007 | Toshiba TN43V71 43" Rear Projection...
No pic no sound
sounds like convergence drive ics or power supply.would be about $350.00 +++ for these type of repairs
Sep 07, 2007 | Toshiba 42H82 42" Rear Projection...
Sound but no picture
sound to me a power supply problem but this is not my field, techman will help you.....good luck
Aug 08, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
158 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
