Question about HP DeskJet 882c InkJet Printer
Color Printing Problem
HP Deskjet 882c - only prints black and red shades. Have replaced color cartridge, aligned and primed. Still no other colors. Any suggestions?
  • 1 more comment
  • fitdtkt Nov 03, 2008
    Just installed a refilled tri-color ink cartidge #23 .
    Cleaned and primed .
    Only prints red -
    I cleaned the cartridge and the only color that comes off of the cartridge is red - no blue or yellow .
    Is it possible that the refilled cartridge is bad ?
  • Neil Parks Nov 14, 2008
    The answer given here does NOT solve the problem. The answer is for no color at all. Like previous posters, my problem is that all the colors are red and yellow--no blue or green.
  • Anonymous Mar 23, 2014
    will not print colors
    President:
  • 4,402 Answers
If a document displays in color on the screen but prints in black and white, try the following solutions. Print a test page to determine if the color cartridge is working
  1. Turn on the printer.
  2. If you have an HP Deskjet 710c, 712c, 720c, 722c, or 820c series printer, follow the instructions below:
    1. Turn the printer on.
    2. Press and hold down the Power button while pressing the Resume button four times.
    3. Release the Power button.
  3. If you have any other HP Deskjet printers, click here for instructions on how to print an internal test .
  4. If the printout is black and white, with no color, follow the instructions below:
    1. Open the top cover of the printer and remove the cartridges.
    2. Verify that the correct cartridges are installed in the printer. Click here to see if you have the correct cartridges . If the correct cartridges are installed, make sure that the tape has been removed from the cartridge nozzles.
    3. Insert the cartridges firmly back in their cradles and close the latches.
    4. Close the printer door.
Verify the correct printer is selected as the default printer
  1. In the software application that you are using to print, click File .
  2. Click Print .
  3. In the Print dialog box, verify that the name of the HP printer you are using is listed in the Name box.
  4. If the printer is not listed in the Name box, click the arrowhead to the right of the box.
  5. Click the name of the HP printer.
  6. Click OK .
Check that the printer settings are correct
  1. Close the software application that you are using to print.
  2. Click Start , click Settings , and then click Printers .
  3. Right-click the icon (picture) for the HP printer.
  4. In the menu that displays, use the left mouse button to click Properties .
  5. In the Properties dialog box, click the Details tab. (In Windows 2000, click the Advanced tab.)
  6. Check that the driver listed under Print using the following driver or Printer matches the HP printer you are using. The following setting may be in one of several places, depending on your printer driver and operating system.
  7. In the Details tab, click Setup . Under Printout, select one of the color options. (If other options have check marks, click in the check boxes to remove the check marks.) If there is no Setup button, click the Graphics tab, and then click Color . Under Color Control, choose a color option, and click OK . If there is no Graphics tab, click the Advanced tab and look for the text Print in Grayscale . If there is a check mark in the box by Print in Grayscale, click in the box to remove the check mark, and click OK . If you are using Windows 2000, in the Advanced tab, click Printing Defaults . Click the Advanced tab. The box by Print in Grayscale should not be checked.
  8. Click OK .
  9. Close the Printers window.
  10. Open the software application that you were using to print.
  11. Try printing again.
Install a new driver If none of the above options worked, the wrong driver might be installed on the computer. For the most current HP printer drivers, go to the HP Web site.
Posted on Jan 09, 2008
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
My deskjet 5550 printer stopped printing in color it only print black ink i have replaced the color cartridge still only prints in blank only; i have tried calibrate printer and clean cartridge options;...
If the Cartridge and printer alignment is successfull and you are still not able to print in color, mostly the Color print is disabled in your pc
Click on START Button
Click on CONTROL PANEL
Open Printers and Faxes folder
Highlight the Printer icon for Deskjet
Right click on the printer icon and choose Printing Preferences
Under Printing preferences, you will find Printing mode - It must be on BLACK or GREY SCALE, Change to COLOR/ ALL
try printing.
Jul 03, 2010 | HP DeskJet 5550 InkJet Printer
Only prints red - changed color cartridge, still only prints shades of red. tried to clean and prime and still only prints red
did you cleaned golden contacts on print head and cartridges with alcohol? if no, try it, other option is, that new cartridge is bad, I had similar problem, bad shades of colors, replaced cartridges and it works now
Jul 10, 2009 | HP DeskJet 882c InkJet Printer
Color is wrong
Have you tried replacing the cartridges? Some programs such as Adobe Reader will generate a "black" equivalent from the color cartridge. In this case, if the color cartridge is low in red, the outcome will be blue. This would signify that the color cartridge needs to be replaced. HP supplied a utility program for the HP6122 to detect and report ink levels. If you have this utility, check the levels. The utility will only work if the computer is directly connected to the printer -- not thru a print server. If you don't have the utility, you should be able to get it at the HP website http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=83028&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=88749
You might find that both the black and the color cartridges are out of ink. Some print drivers can detect when the black cartridge is empty, then attempts to print a black equivalent using the color cartridge.
Mar 16, 2009 | HP DeskJet 6122 InkJet Printer
I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
Jan 27, 2009 | HP DeskJet 940c InkJet Printer
Ink cartridges
The symtoms of a dried out cartridge is white lines through the printed letters.
I've seen brand new dried out cartridges.
Aug 08, 2008 | HP DeskJet 882c InkJet Printer
When printing color, only prints shades of red
Keep on head cleaning until the test print will complete colors.
Jan 10, 2008 | HP OfficeJet r40 InkJet Printer
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
Open Questions:
HP DeskJet 882c InkJet Printer Logo
251 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
