Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Bissell bagless is sucking but the debris are not collecting in the canister. Filters have been cleaned & hose not appearing to be clogged.
    Scholar:
  • 70 Answers
Have you checked the belt. If the brush is not turning,the brush is not sweeping.
Joe
Posted on Nov 16, 2009
I misplaced manual for Bissell Bagless Cleanview II, nothing being picked up in the plastic bin, where to I look for clog other than bottom of hose near bottom plate please?
Recline the vacuum fully to the floor when looking for clogs in the lower hose. You can run a broom stick through the upper hose to remove any clog. Also, check the brush to make sure there is no obstruction. Lastly, make sure all 3 filters are clean and clear because if they are dirty that can restrict air flow drastically. You can purchase filters at www.bissell.com
May 29, 2011 | Bissell Cleanview Helix Deluxe Bagless...
I have bissell powerforce turbo bagless upright vacuum. Its a great machine. It is clogged though. I think I was not emptying the dirt collection tray thing enough. How can I unclog it. Its not sucking up...
remove the hose , clear that , then if you take a wire hanger apart you can pull whatever is remaining out of that connection, also remember to clean ( if you have the cleanable filter) the filter and also the top one
May 18, 2011 | Bissell Vacuums
The vacuum cleaner is not sucking it has been cleaned out so is not jammed up anywhere it just won't ****.
Have you checked the filters?
It is true, you have a bag less machine-- and it catches the big dirt particles in the cyclone device--
But above that are a couple filters-- When they get dirty, you can't have any vacuum!
They really should be cleaned each time you empty the Cyclone section of debris.
Remove them, and tap them clean-- or replace them with new--
I trust that you have already checked the hose-- and it is not clogged?--
Often you can clean the hose, by reversing it-- so that you clean it from the handle, backward into the machine..
Dec 28, 2010 | Dyson DC11 All Floors Bagless Canister...
Bissell Powerforce Turbo is blowing dirt instead of sucking it up! Canister and filters are clean. Help???
there might be a clog down in the nozzle hose or in your main attachment hose. check for suction.
Jan 03, 2010 | Vacuums
Bissell powerforce bagless upright vacuum 6582
Check your filter. Sounds like it is not receiving enough suction to pull up the debris. If your filters are clean and there are no clogs, disconnect hose from back by the tank and see if you have suction straight out of the whole.
Dec 11, 2008 | Bissell Vacuums
Bissell Lift-Off Revolution keeps clogging
Sounds like it is partially clogged. That yellow thing you are talking about, twist it and it should come out, clean or replace the filters, then re-install it. Check the hose and make sure there isn't a clog in it and clean any other filter. One problem with this bagless is the filters will clog up fast and need to be cleaned on a regular basis. Another place a clog happens is in the inlet by the brush roll.
Nov 07, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Eureka bagless uno 12 amp ( green)
Buckaboo, you say the debris no longer collects in the cup? Does that mean you don't have suction as well?
The brushroll has it's own motor so the brushes spinning doesn't necessarily mean there's not a problem with the wiring, the switch, or the motor.
Assuming you haven't inadvertantly set the selector switch to floor when you wanted to use the hose or vice versa, try the following.
Start with the motor/impeller first. Take the dust canister off and turn the vacuum on. It doesn't matter if you turn on the brushroll or not as you're looking for suction.
With the vacuum on feel for exhaust out the front of the motor (by the secondary handle on the bottom. Also put your hand over the area where the dust canister sits. You should feel strong exhaust and suction respectively.
If not, then you should take it in to a technician as going any further requires disassembly.
If you feel there's enough suction, then it may be as simple as a clog. This vacuum has a particularly easy air path to check. There's a clear snap-on door on the bottom to check the brushroll and neck. Then from there it's a straight shot through the canister itself before dumping inside and going through the filter. If it's the hose, you can turn the end clockwise to remove it from the body of the vacuum and use a broomstick to clear any clogs.
If it's not a clog or filter then you may try cleaning the seals (one round at the bottom of the canister where the canister mates to the body and a rectangular one in back of that where the dust runs up and into the canister.
Good Luck!
Oct 03, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Will not suck
You must still have a clog, check the dirt inlet down by the brush roll(#23) for a clog. Do you have suction at the hose end, if you do, then it is clogged down below. If you don't then either the hose or filters are clogged.
Feb 27, 2008 | Bissell 3576 CleanView II Bagless Upright...
Bissell Powerforce Bagless Vacuum
Either your hose is plugged, or the inlet by the brush roll is plugged. Another problem that can cause this is the the filters are clogged or may just need to be replaced. Most of these has a filter in the dust catch bucket, and also above the bucket. Make sure all filters are clean.
Jan 05, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Want suck
some form of blockage in hose
Oct 22, 2007 | Bissell 6594 PowerForce Bagless Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
175 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
