Question about Mitsubishi VS-60805 60" Rear Projection Television
1080i connection has green hue
I have a Mitsu VS-60805 rear projection I purchased in 2000. Everthing is fine except my 1080i connection. The picture has a green hue to it over the entire screen. I have only recently used this connection so I am not sure if this is something recent or has always been this way. Again, all of my 480p component an SD connections are working fine. My friend mentioned to reinitialize the convergence IC via the service menu, does this sound right?
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 28, 2008
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805
What you probably see is a burning area due to Cooling Fluid leaking from one of the CRTs. If this is the case, It is not worth fixing in my opinion because the Board would have to be replaced and the leaking CRT would also have to be replaced. The availability of the Board is doubtful Due to it's age. You can check at 1800-553-7278. This is Mitsubishi's parts department #.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
No picture but sound
I had the same problem with the same model. If you pull the cover off the speakers in the front , then the small black panel. looking from the front past your lamps are the 3 main boards, the r/h board has wire jumpers connecting to the center board. The set that is closest to you had a bad/loose/corroded connection on mine. All I did was resecure connection(try moving them with your fingertip) and turn TV on and check.
Jan 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Convergence gets very bad the longer the TV is on.
The convergence amps will have number on them starting with STK replacing thes may do the trick or you may just have a poor solder connection at these ic's try soldering them first if no go then replace them look around on the convergence amp cba on the bottom for obviuos bad connections small ring crack are hard to see these ic's work hard that is one reason for their large heat sinks running the set and turning it on and off may have induced fine ring cracks. i amsorry I dont have a schmatic for this set but the ic's do have their (generic) part number wrote on them as do most all transistors and diodes and ic's
Aug 22, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Make TV go to 1080p
make sure that you have your HD source hooked up to the correct input on the tv. you are going to want DTV as the input.
Feb 13, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Picture turns red and blue color after television has warmed up
sounds like u are losing green? is that right. could be loose connections somewhere because it works at start up then fails when it heats up. Look in the yellow pages for a mitz auth servicer or call mitsubishi for one near u.
Dec 13, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Green color/tint over the display
yea you have to call a tech to make repairs to your tv it is having problem in the color circuit good luck
Apr 08, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsu dead, help appeciated
ya this tv needs stk packs there are a lot of people inthis area that will fix it for you ie abt
Dec 04, 2006 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
