Question about AT&T LG CU515 Cell Phone - Black
I have an at&t LG phone. Yesterday, it
I have an at&t LG phone. Yesterday, it started peeping, the battery light is flashing and the phone gets extremely warm to the touch.
Orange light flashing battery & screen doesn't light up
if your phn had sparked than it had burned inside parts you should concern imiediately the mobile repairer. thank U!
Sep 22, 2013 | HTC Vivid
Lg vu is stuck on re-flashin screen
Remove your battery for a few minutes. If you use a SIM card in your phone. Remove it also.
Replace all & then attempt to power back on. If this continues; try a new battery.
Jun 21, 2010 | LG Vu CU920 Cellular Phone
Bought this phone yesterday one has charged and is working the other one is dead what am I doing wrong ? madasahatter
Dear hattermadder
You are probably not doing anything wrong. My guess is that the batterieswere not good enough. The batteri sign can show a "full" batteri and after a 5minutes conversation on the phone a peeping noise
starts and suddenly there is no one at the other end.
Try changing batteries and make sur they are the correct ones.
Jun 11, 2010 | Lands Phones
Infinit loo between online and on battery?
With all 5 units behaving the same, I would expect that the power is still out of range. If the power is too high or too low (see manual for thresholds) the unit will stay on battery power to protect the attached equipment. If you have the software loaded, it will show you what the input AC voltage is at. Otherwise, it could be time for new batteries: http://batteryinternational.com/apc-smartups-1000-ups-battery-ups-batteries-f2.html
May 09, 2010 | APC Smart-UPS 1000VA UPS System
shady545, If units have batteries older than 3 years of age, they may need to be replaced. I suggest you evaluate each unit one by one and try swapping in a new set of 12v 12ah or 18ah fully charged batteries to see if that will clear-up the problem in at least one unit. I had to replace both batteries in my APC1250 when one battery developed a shorted cell. Let me know what you find out with your units. 12fixlouie 30min north of Windy City
Mar 17, 2010 | APC Smart-UPS 1000VA UPS System
Flashing orange light, third from the left on the front edge, left side. Just replaced the battery yesterday.....
I had same problem. PC wouldn't even start at all. New cord & battery.Computer repairman said- remove battery, remove electrical power (& unplug the cord from power source :) don't electrocute yourself), then press the start button for at least 30 seconds. I pressed it for about a minute. Replace battery & power, (don't forget to plug the cord into electricity again), and press start button. That resets something inside.
It worked!!!! I couldn't believe it. I almost gave it away before I called repair guy. Yikes. :)
Feb 17, 2010 | Dell Inspiron B130 Notebook
Manual for a pro form 930i treadmill
Hi, my device wan't start. Console is lighting, but only few touch knobs makes sound "peep" and "peep - peep". Manual knob is lighting RED. Unfortunately I can't start it. Can you give me advise for this problem?
Sep 20, 2009 | Exercise & Fitness
Light next to camera lense won't shut off.
This light is the flash for the camera. I would first try to go into Get it Now, then (2) Get Pix & Flix, Then (6) Take Pix, then options - (3) Flash and turn off. If this does turn it off then do same steps and turn Flash on (if you want flash for your pictures. Otherwise leave off.
If this does not work remove the battery for a minute or 2 and then reinstall the battery and see if this resets the flash.
Aug 21, 2009 | LG VX8300 Cellular Phone
AT&T LG CU515 Cell Phone - Black Logo
52 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
