Question about Sewing Machines
Older Bernina 730 from Sweden change to work here
I have an old Bernina 730 that I took with me from Sweden, I was wondering what would be the easiest way to make this machine workable here? Do I have to replace the motor or would there be an easier way? The contact needs to be changed to.
Could you please explain to me what changes there needs to be done.
How much do you think it would cost me to have you do that?
It is a great machine and it would be sad not to be able to use it.
Thank you,
Hi Lillian,
Presume you got my suggestion for a converter...? Coincidentally about a week ago I got a Bernina 730 Record complete except the 220 volt motor was shot. Now I'm looking for a replacement motor. Wanna sell yours? Or do you have a spare? (just had to ask).
Malcolm, Valencia, CA
Posted on Mar 10, 2008
Buy a "step down/step up" voltage converter that will let the 220 volt machine motor operate fine on 110 volt. I'd suggest a 200 to 300 watt converter and will cost between $25-30.00US. You can buy one at an electronics store or on the internet. I use one with my Elna and it works great and is much cheaper than replacing the motor (if it worked in Sweden) especially for a Bernina. Don't let some Sew n Vac store tell you it won't work with a voltage converter and that you have to replace it. He'll turn around and sell it for $300-400.00US. It's a fine machine that will last a long time with an occasional oiling.
Malcolm. Valencia, CA
Posted on Feb 06, 2008
Is it possible for the consumer to download firmware for bernina 730
Hello, Charlotte -
The Bernina 730 sewing machine was manufactured between 1963 and 1982, before Bernina came out with their first computerized sewing machine, the 1130 model.
Are you asking about the Bernina Artista 730 sewing machine, instead? If so, the answer is MAYBE.
I did find a brochure for the Bernina Artisa 730E model, which has a Microsoft Windows operating system built in and the myartista portal (online.) This is the link to the brochure (PDF document):
You may find this information on Bernina software products and which versions of Microsoft Windows software they are compatible with instructive:
Best wishes.
Feb 03, 2018 | Bernina Sewing Machines
Can monogram wizard still be compatible with Bernina 730?
Probably depends whether the OS of the program is compatible with the machine. Most of the time, older programs use Microsoft XP or older.
Your local Bernina dealer should be able to help you.
Feb 12, 2017 | Bernina Sewing Machines
I have a bernina 730 and it does a fabulous straight stitch but it won't do zig zag or any ornamental stitches
Assuming this is the older mechanical Bernina 730 Record (not the new computerized model)...Sounds like your machine is seized due to dried oil.
Wheel on right side that controls the needle up and down is very tight...
Jan 09, 2017 | Bernina Sewing Machines
Bernina Record 730 - made in 1965ish. Recently he has started sewing very slowly although the bobbin winder worked normally. We cannot find out why this is happening.
Oh, no! Do NOT give up on your oldie but goodie! The symptoms are common with older mechanical machines. These machines are wonderful and deserve to be given another chance. Most often, the old oil solidifies and causes the moving parts to seize. With persistence, patience, and a couple of very simple supplies, many of these machines are happily sewing again. The secret is a combination of Tri-Flow and heat and making sure that "all" the moving parts get lubed, even the stitch levers and dials. I have resurrected several older Berninas using the following technique. Several completely seized machines required multiple repetitions over a period of days. If the machine does not have any cracked gears, most likely it can be made worthy again and make your grandmother proud that she gave you such a lasting, wonderful gift.
Resist the temptation to try to run the motor until the machine has gone through a thorough "treatment" and is moving freely manually. Once the machine is moving freely, you will rejoice at the happy and satisfied sound it makes!
Good luck with your lovely!
How can fix stuck needle bar on my Bernina 730
Nov 28, 2016 | Bernina Sewing Machines
Bernina 730 how do I change feed dog pressure it is way to high not touching fabric when down??? Help please
There are actually two Bernina 730 machines (confusing, huh?). One is the 730 Record from around 1960. The other is the more modern 730 computerized model made in the 21st century.
The 730 Record has a hidden pressure adjustment. Lift the top cover and locate the screwhead on the very left side (left of the takeup lever knuckles). This screw loosens or tightens the spring that applies pressure on the presser foot.
The manual can be downloaded here, although it does not show the pressure adjustment:
BERNINA Sewing Systems
On the computerized 730, the pressure adjustment is on the screen (pg 37 of the manual):
Jun 25, 2016 | Bernina Sewing Machines
Bernina 730
try changing the needle--one for the fabric being sewed
also the zig zag could have a worn or damaged gear or cam
or there could be a timing problem.
Apr 11, 2014 | Sewing Machines
Bernina Record 730 hand wheel stuck
Feb 06, 2014 | Bernina Sewing Machines
Bernina 730
I have lost the cord lead to my Bernina 730 sewing machine and cannot get any spares locally. Can anyone out there help find a replacement.
Jan 14, 2008 | Sewing Machines
Sewing Machines Logo
499 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
