Question about Microsoft Windows Vista Ultimate Edition
Dual toner card
The system goes with 2 TV Tuner cards which can be used with the condition 2 as mentioned on hp.com website Tried RF Connector to use the 2nd TV Tuner card. When the automatic setup or manual setup was ran using the RF Connector, no channels were detected. Tried using only one TV Tuner card and could see all the channels. used a splitter to connect the antenna cable to both the TV Tuner card. Both the TV Tuner input is detected but not able to view all the channels on the both the TV Tuner card. Also cannot use the feature of Recording and Viewing simultaneously.
Ex: When recording channel 2 and flipping to channel 3, the system would prompt "Would you like to continue recording." When pressed "Yes", the TV Tuner card is switched but cannot see the channel 3 on the other card but can see some other channel.
    Scholar:
  • 131 Answers
You will have to install each tv turner software not different folder in the program files folder.
During the installation of the drivers and software you will be prompted with the directory where the software will be installed, on this page you should select say for eg:
for the first tv turner card C:\program files\ hp tv turner
for the second tv turner card say c:\program files \hp tv turner 2
this should be done for every directory mentioned during the installation.
other wise both the card will try to use the same driver and software files, there will be a clash, thus one one tv turner card will be viewed.
Posted on Jan 10, 2008
Tip
HP Express Card Digital / Analog not working
First thing I tried to do was to install the drivers that came into the CD didn't work, just using mydvd9 the import/aqcuire option I could have some noise signal, but couldn't find a way to select channels and hanged after a while. This is too trickier, I thought, it should be a way to used quickplay and other applications.
I couldn't get anything from HP site so investigating I found the following.
1) Had to upgrade quickplay to latest version (is pretty cool btw)
2) The card internally is a Hauppage and found that is actually the HVR1500 http://www.hauppauge.com/site/products/data_hvr1500.html.
Drivers + application can be downloaded at http://www.hauppauge.com/site/support/support_hvr1250.html
3) After upgrading quickplay and installing drivers and application from hauppage, Quick play had additionally an hp digital tv tuner entry, but here in canada there is no digital signal transmitted through antenna.
4) I have reinstalled manually the drivers that came in the CD, but from the c:\swsetup\HP Digital tv tuner folder
5) After this I had at quickplay a second source "Hp Analog Tv tuner" which allowed me to caputure the regular air signal and wintv worked as well
I'm sure that I did some redundant steps, but it worked and now can I have everything working (quickplay, wintv, digital, analog signals)
Hope this helps and btw I haev uploaded the manuals for thouse who can't get it, since HP doesn't have them in the website.
Cheers
Alejandro
on Feb 08, 2008 | HP Expresscard TV Tuner For Windows Vista...
System multimedia software with Tv card
I have used a Tivo model 1 for years and love it. But when it came time for HDTV, I decided to try a "build your own" PVR using SageTV or Beyond TV. I have done so and, to make a long story short, I just bought a Tivo Series 3.
Problems with the Beyond TV and Sage TV approaches?
1) Tuner cards with drivers not compatible with running two cards together (Dvico).
2) Tuner cards that cannot accept cable cards and so limit you to OTA HDTV and analog cable channels. I now consider this THE major unresoled limitation in trying to build a PC version PVR to compete with a Tivo Series 3) Don't buy Tuner cards without a hardware encoder on analog channels. This causes excessive CPU utilization and can result in stuttering video when recording two analog channels and watching a HDTV channel. This with a dual core 4200+ghz cpu and this was better than two other MBs I tried. Note: Recently, ATI has introduced the ATI Theater 650 chipset based tuners which ARE reported to have a hardware encoder for analog TV channels. I would recommend this tuner as a starting point for any future PVR build efforts.
4) SageTv has lots of features for "geeks" but is missing lots of features.. Such as an easy way to tell the software to pick HDTV channels instead of non-HDTV channels that are presenting the same program.
5) BTV has a pretty good GUI and good remote controls. Still, it suffers from stuttering and pixelation when recording two analog programs while watching an HDTV program. This is really a hardware problem (3 above) but I was not able to overcome it at the time. I needed a PCI or PCIe HDTV+analog TV tuner which included a hardware encoder for the analog capture mode. BTV has about the worst technical support of any software company I have ever worked with. But the software works pretty good. Their refusal to give me a "baseline hardware configuration" that they KNEW would work with Beyond TV software and two HDTV tuners should have been a red flag that I was going to have problems.
6) I had to go through three video cards before I found one that would give me dual displays while playing back HDTV. Even so, none of the ATI or Nvida based video cards would allow operation of the TV set as the secondary display. This was a result of the huge CPU load generated when making the HDTV display the secondary display and the computer display the primary. I finally settled for a configuration where I used ONLY the TV display and made it the primary display.
So.. After spending three months of elapsed time and about two thousand dollars buying hardware and software to experiment with, I decided to give up and buy the $800 Tivo series 3 PVR with the $199 lifetime subscription transfer price. Expensive, but I spent considerably more (and a LOT of time!) trying to get a dual tuner HDTV alternative to work and .. I failed to come close to Tivo Series 3 features and performance. Until December 31, Tivo series 1 and 2 owners who have a "lifetime" update deal can transfer this deal to a series 3 for $199. This seems excessive considering that BeyondTV and SageTV give "free" TV Guide service "forever" as a part of their software purchase.. That was one of the attractions to these two software packages.
In summary.. A lot of people appear to get BTV and SageTV to operate acceptably in specific applications. A lot of other people have a multitude of problems with their configurations. I simply could not find a combination of hardware and software that would work "without video stuttering under some conditions" with dual HDTV/Analog tuners. The failure of both SnapStream (Beyond TV) and Sage TV to publish even ONE "baseline hardware configuration" that is guaranteed to work under all circumstances with dual tuners makes me very suspicious that such a configuration is unknown at this moment in time. Let
Jul 16, 2010 | Intel Motherboard
How can I watch Television on my laptop?
you may need an external TV tuner connected to your laptop, the cable signal/connection will be connected on the tv tuner.
Let me know for any clarifications
Sep 05, 2009 | Acer ASPIRE 5720-4649 Notebook
Problem with LenevoY510 laptop in TV tuner adapter
From your description it appears that the R-Female connector is for the TV aerial (a coax cable that connects the tuner to the aerial). This is located on the LHS at the front corner next to the IEEE 1394 connector.
The external video output is the S-video connector and this is located on the RHS next to the DVD/CD drive.
These cables common and can be purchased at the TV/electronics shop.
May 02, 2009 | Lenovo IdeaPad Y510 Notebook
Got a new Dell Studio 17 laptop with TV Tuner, but TV wont go
if it is not finding channels, it could be a physical connection problem from the antenna or the antenna lead on the device.
Mar 10, 2009 | Dell Studio 17 Laptop
No Sound is there while using SAA7130 TV Card
I am using p4 dual core intel processor 3.06 Ghz. Recently i installed tv tuner card on my suystem with cabil connected to this card. but due to unknown reasons sound stopped coming. though the picture is still there i am using Windows vista . My system config is 2 GB DDR2 ram and tv tuner card with 80 gb HDD + FDD
Due to this problem I formatted my hard disk and re-installed everything but the problem remained i re-checked everything with no results.
can you help me to sort out this.
thanks
Dec 29, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
TV TUNER DRIVER
One. did you call microsoft to help with that problem.
two. http://www.hp.com/country/us/en/welcome_acc_supp.html#Support,
three. Did you try reinstall vista ultimate again.
four. or install the card in another slot.
good luck....
Nov 04, 2008 | HP Expresscard TV Tuner For Windows Vista...
HP ExpressCard Pavilion Notebook
its definitely something you did.
theres a way to wipe system back to original pn hp screen.. F10.. that might fix..
if it dont. then bios is the issue.
Dec 20, 2007 | HP Expresscard TV Tuner For Windows Vista...
Hp z558
This sounds like a poor put together pc. If the DVD drive does not eject then either the dvd is faulty or the IDE cable and/or IDE1 connector on motherboard is not installed, try ejecting through my computer(right click on drive then Eject), if this works the button is faulty. The same goes for the TV Tuner card, again possibly a corrupt or non installed driver, try re installing mother board drivers and card drivers. This really needs to be returned as the pc is not fit for it's use.
Feb 19, 2007 | HP z558 (EG652AA) PC Desktop
Microsoft Windows Vista Ultimate Edition Logo
160 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
