Question about Samsung Jet S8000 Cell Phone
At the top of the screen i have two yellow hands clasping, and the screen doesn't work anymore. why?
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
Aug 26, 2014 | Paolo Gucci PG501TW Wrist Watch
How to fix white screen in ds lite gei
hi, it may be that the top screen ribbon cable has come unseated from the clasp and may just need undoing the black clip, pulling out the cable and putting it back in but unless you have taken these consoles apart are tricky and delicate. Most probably needs new screen tho to be honest. screens are only about 7.50 but require soldering skills for speakers, a steady hand and patience. google or YouTube replacement top screen ds lite for videos. I have done 100's. I charge between 12-15 to replace.
thx
Apr 19, 2013 | Nintendo DS Lite
The screen won't turn on anymore after I took it apart to switch out the charging port.
I see a crack in screen on top right but it should still display (however touch won't work). Look at the ribbon connector which connects display to the phone PCB, it should be firmly secure in its connector.
Also try cleaning the PCB with alcohol, if still doesn't work then either you need a new LCD or some chip is blown.
Nov 10, 2012 | Lands Phones
How do i get the filter on? i can not get the filter under the clasp at the top.s
You need to install top of filter under clasp first and at an angle w/ bottom angled out. Then, the bottom should slide in. You may need to push a little on the clasp w/ the filter.
Jul 16, 2011 | Ecoquest Fresh Air Air Purifier
I have a Givenchy necklace with a broken clasp. I need to purchase a new clasp and have it attached to my necklace. Who does this sort of repair or where can I purchase a new clasp?
Just about any local jewelry store can repair this. Just go to the yellow pages in the phone book and look under jewelry repair. I know that Zale's and Clark's Jewelers can repair it. And they should have a new clasp also.
Nov 30, 2010 | Givenchy Watches
Clasp to lid console top box broken. How do you
This part is available at your local Infiniti dealer. The plastic part is replaceable.
Feb 09, 2010 | 2008 Infiniti FX35
The interior handle won't open the door anymore, what is the best repair?
The interior handle is attached to the lever that opens the door by a long rod. That rod is a secured by a little plastic clasp that sometimes breaks over time.
You must remove the inner door panel and you may have to fish inside the door to get the rod (sometimes it falls over when the clasp breaks) and replace the clasp. The clasp isn't very expensive at all, and the job of replacing it isn't that difficult.
I hope this helps.
Aug 19, 2009 | MTX T-Form 92-99 Suburban Red incl. 10"...
Canon MP 600 cartrige recognition
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 29, 2008 | Office Equipment & Supplies
Samsung Jet S8000  Cell Phone Logo
65 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
