Question about Belkin Computers & Internet
Trying to set up a second computer for wireless
Trying to set up a second laptop computer for wireless access. Receive message ''Acquiring IP address'' and that is as far as I can get. Second computer is a 2005 vintage Dell utilizing XP. Network is active and indicates I am connected but IP address appears to an issue in accessing the internet. The first computer I hooked up works fine.
What wireless mode is you router operating in? Does it support the cards on your other systems?
Do you have mac address control enabled?
Try disabling security temporarily to see if you can connect; your wireless connection may not be setup to authenticate properly.
Posted on Nov 17, 2009
The wap54G is having issues. Computers trying to connect to it keep acquiring ip address and never connecting. Any advice on what might be wrong?
Hi williamrayes,
If you have a message that acquiring ip address you can Power Cycle the router for 2 minutes then try to connect again or you can try to check if the Network Key that your typing is correct (If the connection is secured). You can check the Network Key of your router by accessing the Wireless Settings Page of your router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security, You can personalize the Network Key if your want. Save the settings then try to connect.
Rate me if this helps so I can help others.
Thanks for using Fixya.
Feb 04, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
My laptop keeps acquiring network address. Please suggest what to do ? Router --> Modem --> Desktop. Laptop is for wireless connection
For that you need to enable DHCP on router.Then your computer get ip address automatic from router.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on DHCP enable it save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Nov 27, 2010 | Zyxel Prestige 320W Wireless Firewall...
Sometimes i try to ping the wireless access point and i get the message 'Request time out',i receive this message even if im directly connected to the access point.what should i do
When you connect the computer directly to the access point, you might not be getting IP address on your computer.
You will need to assign a static IP address on your computer in the range of default IP address of the Access point.
Click Here for More info on access point
Oct 08, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
THERE IS AN IP ADDRESS CONFLICT WITH ANITHER
Identify the peripheral conflicting with the router and change the network address on one of the two. Their setup programs should give you the possibility to do so. The address should look like: 192.168.2.x
x ranging from 0 to 9
Aug 02, 2009 | NetGear WGT624 Wireless Router
Acquiring Network Address
reset the modem and the wireless router by powering them off for 30-60 seconds, then plug power back in. Wait a minute or so for the devices to reset then go to the PC and try to connect again
Good luck
Jan 26, 2009 | Dell Inspiron 2200 Notebook
"acquiring network address" problem
The password might have been changed that's why you keep getting "acquiring network address", the password is incorrect. What you can do is just reset the router. There's a reset button at the back of it, press and hold it down for 10 seconds then release, unplug the power now for 10 seconds then plug it back in. That will disable the wireless password, just re-enable it.
Oct 26, 2008 | NetGear WGR614 Wireless Router
Cannot connet my laptop to he wireless router
If compuetr always saying acquiring network address you can try firt restarting the computer, but if still wont get a valid ip address, you need to adjust the wireless settings of the router and after that try to reconnect to the wireless network....
Oct 25, 2008 | NetGear WGT624 Wireless Router
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
Acquiring network address
if you are using the dell wireless utility to manage your card, then disable it, and manage your wireless adapter through the windows network connections. that way the wpa issue will be solved by windows xp wpa. i had a similar problem with my inspiron 1525 (dell wireless 1395)
Jun 09, 2008 | Computers & Internet
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
80 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
