Question about HP Pavilion a305w (DM181AR) PC Desktop
Start up when i start my computer , it runs, then stops and goes to the window that asks me if i want to run the computer on safe mode, safe mode with networking, safe mode with command prompt, or start up computer normally. When i run it on safe mode, it goes back to the safe mode window.
  • lesbn man Jan 09, 2008
    i tried, but it stops and returns to the same safe mode window.
  • Anonymous May 21, 2008
    Inadvertently switched off power when shutting down. On start up asks if I want to run in safe mode, last known config etc etc, but which ever option I chose it flicks to 'welcome' then back to start up window. Seems to be stuck in a loop
    Sergeant:
    Champion:
  • 317 Answers
Try starting the computer normally, this usually happens if you computers power was cut while booting up, its just a small harmless glitch.  As for the returning back to the prompt try running it with command prompt. when you get to the command prompt, type (chkdsk) and let it run this might also fix any other problems that you are not seeing.
Posted on Jan 09, 2008
2 Suggested Answers
NitrusInc
  • 326 Answers
SOURCE: Computer Will Not Boot
You will need to do either an in-place upgrade of your Widows OS
Or
Use a System Restore Disk.
Let us know what happened prior to these issues so we can give you a better estimate of the necessary steps to get you on your feet.
Good luck
Posted on Apr 14, 2009
Emachines T6524 won't reboot after automatic update. I get the windows screen when I turn it on, and everything seems fine, then the screen goes black and I get the no signal message.
You should try to boot in safe mode without the card removed..If this got on after an update it is possible (almost sure) it messed up with your graphic card driver and now it needs to be reinstalled > To do so ..try to boot in safe mode...To do that press the key indicated on screen for boot menu and choose safe mode ...usually it is f8 key or f12 ..depend on the model .If it seams not to be able to find the safe mode boot ..try to stop the computer by unplugging it ..This will force it to stop improper way ..and will show the screen for safe mode and other ways to boot-up .select the first safe mode ..and let it start ..This mode will not load any drivers and work just with the minimum needed for to start .Go to control panel ...remove programs ..and remove the graphic card driver from the list ..after that if you have the disk insert it and run the driver again in original ..If you do not have it look for it on the manufacturer's site ..and download it ..
If you need help with the driver ..let me know exact model of the computer ..and if it is not an on board card I need to know the exact model of the video card ..
Dec 30, 2011 | eMachines T Computers & Internet
Windows does not shutdown properly, asks me if i want to restart in safe mode?
It never hurts to start in safe mode. While in safe mode, some things will not be available to you. Be aware that there is a reason your computer is telling you to start in safe mode. Something happened, hardware or software related, that caused a problem. Windows allows you to start in safe mode to correct problems. Not knowing what the problem was, I might suggest starting in safe mode, then go to start, all programs, accessories, system tools, then system restore. Try to restore your computer to a few days ago when it was working properly. Then restart, and hopefully it will work.
Aug 22, 2010 | Acer Aspire One PC Notebook
Starting up loop that never ends.
Try booting in safe mode (F8 just before the Windows screen) and do a virus check.
Stelios.
Feb 21, 2010 | Dell Inspiron E1505 Notebook
Laptop will not start up the toshiba oening page shows on screen then the screen goes blue with only the cursor showing
For that when you power up the computer press F8 key then enter into safe mode and if you able to enter in safe mode.
Then first remove temp files from computer.
Go to start->run or press windows key + R key then you can see run type in run "%tmp%" then press ok then delete all temp files then type in run "prefetch" press enter delete all prefetch files.
Type in run "chkdsk /r" then press ok then press "y" then restart computrer then it fix error on harddrive.
Also scan computer with updated antivirus then it works fine.
But if you are not able to enter in safe mode.
Then you need windows disk for that insert that disk into rom then enter in bios and set first boot device as cd/dvd rom then save settings and exit from bios .
Then it boot with that windows disk.
Then follow the procedure on screen and choose options are when it ask for "Repair previous windows" .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 17, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop start up error
This error comes when there is memory issue .
Harddisk issue or RAM issue.
For that if you have windows recovery disk you need to run disk checking program
Most of this error comes becuase of hardddisk error.
Boot your computer with windows xp disk then enter in recovery console mode then type in prompt "chkdsk /r"
then press "y"
then it checks disk andf fix error if found any error on harddisk.
then you can boot your windows.
Thanks for using fixya.
Please rate my solution if it hleps.
Pls let me know if you need more assistanse.
Many Thanks .
Jul 24, 2009 | Acer Aspire 4315-2963 Notebook
Computer wont start in safe mode
Click On Start---> Run---> MSCONFIG---> click on BOOT.INI --> Then Click On Safe Boot --> Click Apply And Click Ok---> Restart Your system u'll get what u want.......... Temme If u need any help in virus removal...
Plz Rate This Solllution If It Works For u
May 21, 2009 | Microsoft Windows XP Home Edition
Computer won't start
this is a complicated fix to diagnose over emails but first, the hd had been hit the power outage while accessing the hd can damage it. so I recommend reloading windows fresh if it cannot then you may have damaged the cd rom /dvd drive.
what version of windows are you running?
Apr 27, 2008 | Computers & Internet
Unable to boot the computer
start the sys and press F8 KEY to go to safe mode.
then run chkdsk
Apr 03, 2008 | Microsoft Windows XP Home Edition
HP Pavilion a305w (DM181AR) PC Desktop Logo
161 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
