Question about HP LaserJet 4 plus Printer
Replaced cartridge, but print quality is dull
  • 105 Answers
Make sure you toner density is set to 3. If it is, try it at 4 or 5. The other thing to turn off is toner saver.
Posted on Nov 24, 2009
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
HP 1600 prints with left side smudging
If you are ask printer paper Quality then first you check it ink label and then you check paper quality because both are depend which types of quality you are used. If one in dull then printer quality also dull. I share a print quality related link please read and follow instruction.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01691481
Thanks,
HP Printer Support
Apr 04, 2014 | HP LaserJet 1600 Printer
Cleaning inkjet nozzles
Here's what I found here:
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Cleaning the print cartridge nozzles
To improve print quality, you may need to clean the print cartridge nozzles.
Clean the nozzles when:
• Characters are not printing completely.
• White dashes appear in graphics or printed text.
• Print is smudged or too dark.
• Colors on print jobs are faded or they differ from the colors on the
screen.
• Vertical, straight lines are not smooth.
43
You can use the operator panel or the Lexmark X5100 Series Solution
Center to clean the nozzles.
Using the operator panel
1 Load paper in the All-In-One. For help, see page 16.
2 Press Options until Cartridges appears on the display.
3 Press the right arrow until Clean appears on the display.
4 Press Select.
A nozzle page prints forcing ink through the nozzles to clean the
clogged nozzles.
5 Print your document again to verify your print quality has improved.
6 To further improve print quality, try wiping the print cartridge nozzles
and contacts (see page 44), and then print your document again.
7 If print quality has not improved, try cleaning the print cartridge
nozzles up to two more times.
Using the Lexmark X5100 Series Solution Center
1 Load plain paper in the All-In-One. For help, see page 16.
2 Click Start Programs Lexmark X5100 Series Lexmark X5100
Series Solution Center.
3 Click the Maintenance tab.
4 From the Maintenance tab, click Clean to fix horizontal streaks.
5 Click Print.
clogged nozzles.
6 Print your document again to verify your print quality has improved.
44
7 To further improve print quality, try wiping the print cartridge nozzles
8 If print quality has not improved, try cleaning the print cartridge
Wiping the print cartridge nozzles and contacts
If the print quality does not improve after cleaning the print cartridge
nozzles, dried ink may be on the nozzles or contacts. To wipe the print
cartridge nozzles and contacts:
1 Remove the print cartridges. For help, see page 38.
2 Dampen a clean, lint-free cloth with water.
3 Hold the cloth against the gold nozzle area for about three seconds.
Gently blot and wipe dry in one direction (this prevents the colors in
the color cartridge from mixing).
4 Hold a clean, damp section of cloth against the contacts for about
three seconds. Gently blot and wipe dry in one direction.
Nozzles
Contacts
45
5 Let the nozzles and contacts dry completely.
6 Reinstall the print cartridges, and then print your document again.
7 If the print quality has not improved, try cleaning the print cartridge
8 If print quality is still unsatisfactory, replace your print cartridges. For
help, see page 38.
Jun 29, 2011 | Lexmark X5150 All-In-One InkJet Printer
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
I have replaced a yellow cartridge and the colours
If this is a remanufactured cartridge, and its the yellow (new cartridge) that has gone weak, this could be caused by a missing idler gear.
I do the QC checks on a lot of these cartridges and have seen the occasional missing gear. It can happen sometimes.
The cartridge could have tested OK at manufacture, but then deteriorated in use
First, check the end of the cartridge with the white plastic 'end cap'. This is held on by a single screw (don't loose it, or the spring that pulls the two halves of the cartridge together).
Having removed the end cap being careful not to damage it, if the small idler gear is present, it will look like the following picture.
If the small idler gear is missing, this WILL cause rapid deterioration of print quality, certainly within 50 pages and I would have expected to see deterioration within less than 30.
The other side of the cartridge is more difficult to remove, and there are therr idler gears at that end, any 1 of them if missing will cause deterioration of print quality, though I would expect more than 50 pages before it would show.
Regardless, if the cartridge is new OEM, or new remanufactured, it should have some sort of warranty, so talk to your supplier.
Apr 21, 2010 | Dell 3110cn Laser Printer
Color is dull
If you have the Lexmark software installed, you should be able to select the print quality through that most packages offer a choice of print density (dot per inch) and/or 'Draft,' 'Normal,' 'High' qualities whereby you can trade off quality for economy. Variations in paper quality can also have a huge influence on the contrast and color saturation.
Dec 06, 2009 | Lexmark X4530 InkJet Printer
My Lexmark Z 515 printer does not print clearly especially the second part of a piece of paper. How can I clean the printer?
1 On the operator panel, press Options repeatedly until
Cartridges appears.
2 Press the right arrow button until Align appears, and then press
Select.
An alignment page prints. Once the alignment sheet prints, your
automatic alignment is complete.
You may need to clean the print cartridge nozzles.
4 Press Select.
clogged nozzles.
6 Try wiping the print cartridge nozzles and contacts, and then print your document again.
Load plain paper in the All-In-One. 2 Click Start Programs Lexmark X5100 Series Lexmark X5100 Series Solution Center.
5 Click Print.
7 Try wiping the print cartridge nozzles and contacts, and then print your document again.
4 Remove the old cartridges
Hope this helps.
Thanks
Have a good day.
Dec 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
Smasung ML2510 Laser print quality poor especially on graphics
Full isn't always the answer, in order to refill a cartridge properly you need to also replace the cleaning blade inside. The blade wears out and doesn't clean the drum properly and also lets toner leak all over. Your best bet is a new OEM cartridge, or put a new cleaning and Dr. blade in yours.
Jul 29, 2009 | Samsung ML-2510 Laser Printer
Print is dull.
Listen I have seen really, bad print ctgs from HP, before you drive yourself crazy replace the ctgs again, see if your print quialty improves. just cause it's new doesn't mean it's not defective.
Mar 07, 2009 | HP DeskJet 5150 InkJet Printer
Color cartridge problem
The first thing I thought of when I read your message, was whether or not your replacement cartridges were produced by HP or by another company. Also, was it a brand new cartridge or a refill? While buying ink cartridges from another vendor or "recycled" cartridges may save a buck or two, you can't always rely on the quality of the printouts they produce. If this is the case, try using an HP color ink cartridge and see if that produces better print quality.
If you are using HP ink cartridges, there might be an issue with the contact between the cartridge and carriage. It's an electrical connection and if the contacts get dirty, it can affect print quality...sometimes drastically.
Unfortunately, HP.com doesn't have a web page dedicated just to cleaning these contacts. Fortunately, they included those instructions in the following document:
Replacing the Print Cartridges
When the web page opens, scroll down to the bottom of the page and locate the task, "Fixing error messages that appear after changing a cartridge". This will contain instructions on how to clean those contacts. See if this helps.
If all else fails, try going to the following web page:
Correcting Print Quality Problems
This is sort of a "catch all" web page with a large collection of print quality diagnostic and repair techniques. If you've gotten this far wtihout a solution, perhaps something on this page will help.
Good luck.
Oct 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP LaserJet 4 plus Printer Logo
66 people viewed this question
Seeker5211
Seeker5211
