Question about Hotpoint RB787 Electric Kitchen Range
The front right burner will stay red hot after I turn the knob to the off position
    Sergeant:
    Champion:
  • 289 Answers
You nead to replace the infinite switch that the knob hook's on to
Posted on Nov 16, 2009
Both front burners won't turn off.
Replace the switches for burners that are not turning off.
Sep 05, 2017 | Kitchen Ranges
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
Apr 29, 2012 | Kitchen Ranges
I have a GE stove that has a red light for HOT SURFACE
The control switch for the right front burner is bad. A new switch will solve the problem.
The situation,while annoying is not dangerous.
Feb 18, 2010 | GE Kitchen Ranges
Two of my JSP28 range burners are malfunctioning. They will heat up, but will be bright red and be very hot. I turn the knob, but the burner stays very hot. What part/s do I need to fix this problem?
Are you saying that they turn on high no matter what you have them set for? If so, then you probably need the controls the knobs connect to replaced. If you do this yourself, make sure the stove is unplugged or the power shut off to it before you start.
Nov 25, 2009 | Cars & Trucks
Tappan ES 200 burner stays on high and not turning off.
I need to clarify a bit.... did you remove the knob and check where the metal rod inserts into the plastic knob hole? If that is chipped on the inside, it will not turn the metal rod that comes out of the stove. Take the knob off, and use a pliers to turn the metal rod. Leave me comment if you have already checked that or you do not have that type of knob on your model.
Nov 17, 2009 | Tappan TGF320 Gas Kitchen Range
We have a Kenmore model #790.96011407 range with smooth top. It was working fine until recently one, then the other, front burner started operating on their own. They will not turn off when you turn the...
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Jun 27, 2009 | Kenmore 96012 / 96014 / 96019 Electric...
I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Apr 07, 2009 | Kitchen Ranges
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Mar 05, 2008 | GE JBP64 CleanDesign Electric Kitchen...
Hotpoint RB787 Electric Kitchen Range Logo
115 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
