Question about Canon ES20V 8mm Analog Camcorder
Flat cable of LCD of my CANON ES20V
Good Evening. Flat cable of LCD of my CANON ES20V is broken. HWhere can I buy that cable?
2 Suggested Answers
  • 11967 Answers
SOURCE: good evening, lens error, restart camera appears
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 20, 2009
No audio in my Mitsubushi LT-52249...
Your signal board is proably bad and will need replacing.
You can get parts at www.interliquidparts.com
Dec 02, 2011 | Mitsubishi LT-52249 LCD TV
How much screen 4 lxus30 canon
Ebay.com is the best place to look for. If you buy the LCD itself it is usually expensive. For example, Try the following email. They replace the LCD: hu221221@gmail.com
But I would suggest you to buy a used camera (one sold for parts, with good LCd) through ebay.com and replace it yourself. You only need to buy a jewellers screwdriver set for $1 from Dollar store. Removing the case is easy (5-6 screws). Once the case is removed, LCD is immediately accessible.
You can buy any one of the cameras:
Canon IXUS 30 40 50 SD200 SD300 SD400
They all use the same LCD. So look in ebay.com for the above cameras. You may be able to get it for under $10-15. But before you do anything look at the following web sites to get an idea on how to do the job:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Jan 18, 2011 | Canon IXUS V2 Digital Camera
Good Evening, I have a HP laptop and it has a black line about 1 inch wide running vertically on the screen
To me this sounds like there is a problem with the LCD flat ribbon cable which connects the motherboard/mainboard of the laptop to the LCD screen. Does this vertical line always appear regardless whether you are in Windows? If so, then the cable
is either slightly loose or is somehow being pinched by the laptop hinge. Tap or press in the area above your keyboard to see if this goes away. If not, you may have to open up your machine and inspect the LCD cable.
Dec 04, 2009 | Dell Inspiron 9300 Notebook
Buy and replace broken lcd screen
You may be able to fix it yourself if you can find a replacement screen, and you have some basic experience and are comfortable with electronics. Usually there's no soldering involved, with replacement merely requiring unplugging and reinserting the screens ribbon cable in it's connector. I usually search ebay for a broken camera with other problems that I can cannibalize. Here's some examples on LCD replacement:
May 17, 2009 | Canon Cameras
Broken LCD Screen on a Vizio VW42L. Where can I buy one?
Hello Sesman200,
We have a good screen in Stockton, CA... Call us at 209-465-6139 .. Dave
Thanks.
Mar 28, 2009 | Vizio GV42L 42 in. LCD Television
Canon s5is spare parts
Ebay. Plenty of broken cameras with good LCD screens.
Regards,
Dec 19, 2008 | Canon PowerShot S5 IS Digital Camera
Broken lcd z650 digital Camera
Well LCDs can be replaced but they are hard to since they are attached to extremely fine wires.
Your options are
1) try to get it fixed at the manufacturer (they will charge you for part + service)
2) buy the part on ebay and try to look for a service manual (quite hard as the plugs for lcd cables are clips that break).But its the cheapest
3) Buy a new camera (variation in cost) (recommended brand canon or nikon)
Oct 14, 2008 | Kodak EasyShare Z650 Digital Camera
Flat Cable Info.
Best thing for you to do, would be to contact Samsung, and give them a complete description of what flat cable you need to replace. Do not just say flat cable as there are several flat cables in this camcorder. Good Luck http://www.samsungparts.com/customerservices/contactus.asp
Jul 06, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Canon ES20V 8mm Analog Camcorder Logo
22 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
