Question about Sony UP980 Thermal Printer
Sony UP980 won't advance paper to cut image so the next image can be brought up on the screen
    New Friend:
  • 30 Answers
The cutting mechanism is most likely worn and needs to be replaced.
Posted on Aug 08, 2014
I can not get the paper to feed in my Unisonic XL-1149 calculator
Cut paper at a 45 degree angle and load into back slot with angle (apex) of paper to the right of machine when facing it. Be sure to push it thru when loading. You should see tip next to calculator number wheel. Hit the additon sign several times to advance. You may need tweezers to pull paper thru if it doesn't advance by itself.
try this otherwise see the manual and make sure you are not using generic paper roll only use specific paper because the Chinese knock off paper is to thin
Mar 01, 2018 | The Office Equipment & Supplies
Service manual
Can you post a picture of the print
Aug 14, 2013 | Sony UP980 Thermal Printer
I have a sony UP-980CE thermal printer which is having an image quality issue, where the video fades lighter right to left on the film
This can be caused by several things. The first is the door has been hit so it not aligning properly, second is that he platen roller could be worn and the third is that the spring that holds down tension on the head is sprung. 90% of the time its the door damaged because they hang out of the c-arms and people strike them against objects. I have been working on Sony medical products since 1993
Mar 28, 2012 | Sony UP980 Thermal Printer
TIMMING PROBLEMS ON SMALL BLOCK 350 CHEVY
Did you set the computer to Diagnostic Mode by using a paper clip or scan tool connected to the ALDL connector underneath the steering column? Most GM's 1981 and later may need to short pins A & B to set the timing as well as disconnecting the vacuum advance.
See here for ALDL diagram: http://autorepair.about.com/library/images/bl428lib.htm
Aug 21, 2009 | 1986 Buick Regal
Cant seem to get started. everything is hooked up. hoew do i start the game.
well you slide the power button up to turn it on . boot up scree for sony should come up if you get a blank screen double check screen check to see if you have a light image in the black screen if you do *********** board is dead if it's just a black screen you could have someone reflash the firmware but if you get a boot up screen you should wait and see if the psp load screen comes up if you get a plain backround or your wall paper eject the umd if you are brought to the xmd bar your umd is bad need it replace or a firmware update
May 28, 2009 | Sony PlayStation Portable (PSP) Console
How do you load paper into the printing calculator?
Oct 10, 2008 | Canon P23-DHV Calculator
Switches off after 3 to 4 secs--little bright screen hor line and small retrace lines
On the my sony website, they said try unplugging the set for 3 or 6 minutes. Then plug it directly to the wall. If that don't work, and it won't; seek a service center. I have the same problem.
Next time we better buy Panasonic. Sony products fail ALOT. I had a 5 disc DVD Changer and it was defective and it was part of a class action lawsuit,
I believe this is the same sort of problem.
The sony Vaio laptop computer gets consistent poor reviews.
I brought an alarm clock and its back up battery never worked right out of the box.
I brought a cordless phone and the LCD display went blank.
I am so DONE with Sony.
Good name; Bad products.
Aug 23, 2008 | Sony KV-24FV12 24" TV
Sony UP980 Thermal Printer Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
