Question about Microwave Ovens
Goldstar microwave exhaust fan will not turn off
Yesterday had both the lights and the exhaust fan on while using the microwave. When finished was able to turn off lights, however cannot turn off fan. It has been running all night and day and is very annoying. Please give advise on how to turn this exhaust fan off
Thanks
  • Anonymous May 07, 2009
    Same thing, fan was on low, and then kicked into high mode and won't shut off.
We had this happen to us tonight. We unplugged the microwave oven for 15 seconds and then plugged it in, but it the fan was still running. We then unplugged it for 30 minutes and the fan worked properly when we plugged it in again.
Posted on Apr 14, 2008
My Goldstar MV1608 stopped rotating and heating food yesterday. All other functions seem to be operating such as the light, fan, panel, etc. It is 18 months old. How can I fix it?
If there is no heating it is possible that the MAGNETRON has failed provided there is supply feed to the unit when the microwave is powered. Normally the magnetron along with the fan and light comes on when the microwave power is triggered. So since the rotation is absent it is possible that there is no power feed from the processor board which can be related to a driver failure. You need to check the output from the PROCESSOR to confirm and pinpoint the defective component. Check the relay to the magnetron trigger as this can be a suspect.
Oct 24, 2011 | LG MV1608WW Microwave Ovens
How do you change fan exhaust from wall to front of unit.thanks
physically pull up and rotate exhaust blower fan assembly so it points toward the front. you'll need to remove a plate with a common phillips screwdriver.
Aug 06, 2011 | Goldstar MV-1501 Microwave Oven
Goldstar Microwave stirrer fan sparks
Stirrers are designed to distribute the microwaves and were used before turntables were introduced. They are protected by a plastic cover in order to prevent food spatter from contacting stirrer. They are not powered and are insulated on nylon bushings. Where exactly is the arcing occurring?
Dec 11, 2017 | Goldstar MV-1310W/B Microwave Oven
Switch for stovetop light on Goldstar over-the-range microwave
This is caused by a failure in the Sharp solid state relay "chip" (S201DH2). The newer pin-compatible versions don't seem to suffer this weakness. I used the R31HD2 (http://document.sharpsma.com/files/pr21hd22_e.pdf) which should still be available in the US for less than $10 delivered from Mouser or similar retail friendly parts houses.
A simple repair for someone with the tools and basic skills for removing and replacing a chip that is soldered to a printed circuit board. If you lack either of these, better to order a replacement board or have it serviced professionally.
Dec 11, 2008 | Goldstar Microwave Ovens
Goldstar MV1526B
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 02, 2008 | Goldstar MV-1526 Microwave Oven
Light doesn't turn off
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 21, 2008 | Goldstar MV-1501 Microwave Oven
No power
I would say a cooktop lamp got shorted by the moisture.
Assuming your circuit breaker is good, the main problem would probably be a blown 15A or 20A ceramic fuse inside the unit.
Once that's replaced, if the hood lights and /or exhaust fan still don't work, then your control panel would need to be repaired, which we do for $39.95 nationwide.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If and when you remove or install cooktop lamps, the power to the oven must be unplugged or turned off at the breaker.
Mar 15, 2008 | Goldstar MV-1526 Microwave Oven
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Microwave Ovens Logo
789 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
