Question about Maytag HYE3658AY Electric Dryer
Just quit in middle of drying. Breaker checked out fine...
    Scholar:
  • 86 Answers
Your thermal fuse is bad. Pull off back panel - there should be a small white fuse with two blue wires. Replace or bypass (which I don't recommend, but can be done).
Posted on Nov 17, 2009
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Wirlpool Duet Dryer front Load
I have never seen one up close nor worked on one, but if it was me I would look for a cause to the broblem. I would eliminate the simple stuff like power to the equipment and loose connections. I would then look for the fuse on the dryer and find the blockage or cause of the problem.
Posted on Jan 01, 2009
  • 2295 Answers
SOURCE: Dead!! No electrical.Have checked house circuit
check thermal fuse,also see if dryer needs to be cleaned out,clean out lint duct vac out cabinet and go outside and make sure the flapper is opening sometime you need to blow out the vent line,leaf blower works great for this
Posted on Nov 07, 2009
heatman101
  • 43501 Answers
SOURCE: dryer quit working in middle
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jul 04, 2011
My dryer quit working in the middle of drying with one minute left. I turned the unit back off and on to no avail. I turned the unit off. Reset all the breakers including the ground fault breakers...
Suggest you start by checking the electric circuit to the dryer. Make sure that you have approximately 210 volts to the outlet. Chances are that the breaker feeding the circuit or a connection in the circuit has gone bad. Probably need an electrician to repair.
May 16, 2013 | Samsung DV330AE Dryer
Wont turn on
this link is for the manual go to page 12 for troublshooting it could be seversl thing that are quite easy to check,
http://hoover.com/file/682/
Nov 25, 2012 | Hoover Floormate H3000 Upright Wet/Dry...
Dryer was working, quit in middle of cycle. Will
It's rather unusual for any internal failure to cause the dryer to just stop in cycle. Check the circuit breaker that supplies the dryer. It should be a double-pole breaker of at least 30 amps. Turn the breaker off and back on to ensure it is reset. Internal causes could be the motor, door switch, thermal safety switch, timer, or a broken wire.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
I have a maytag model # pye2300ayw while in the middle of drying a load a clothes it just quit i turned it back on now the timer is the only thing clicking nothing else is happening
Check your breaker, then the wiring in the back. It sounds like it could be your thermal overload switch is bad. Does the drum turn on even though it may not have heat? This will help me analyze it.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Dec 29, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag performa dryer quit in the middle of a load
probably the thermal fuse i just fixed mine it did the same thing it was about twenty bucks for the kit and it is located right under the wires that feed the heating element
Dec 15, 2008 | Maytag Performa PAV2200
Asko 7005
Go reset your circuit breaker. Even if it didn't pop out, reset it.
Oct 25, 2008 | Dryers
Maytag HYE3658AY Electric Dryer Logo
244 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
