Question about Sony STR-V555ES Receiver
Sony V555ES RECIEVER
WHEN I TURN ON THE RECIEVER SOMETIMES IT JUST CLICKS RAPIDLY AND WILL NOT STOP TILL I CUT POWER TO THE UNIT. IT WORKS WELL SOMETIMES BUT THE FREQUENCY OF THE PROBLEM IS GETTING WORSE. SOMETIMES OUT OF ORDER FOR A DAY OR TWO AND THEN IT WILL WORK PLEASE ADVISE WHAT I CAN DO . THANK YOU
  • hicig Aug 04, 2008
    Same Here, except it never boots properly any more.
    If I unplug all the dc supply connectors, turn unit ON then reconnect them,eveything works great untill I turn the unit off.
    Going to try ramping up slowly with a variable transformer when I get the time! Maybe its something to do with the inrush current.
It turns on but no sound looked at the internal fuse and it is good disconnected all wires and sterted from step 1 and all new wires can any one help me
Posted on Apr 04, 2011
I came across this article when researching the same problem. I just ordered the parts. Wish me luck.
http://www.agoraquest.com/viewtopic.php?topic=10988&forum=51&keyword2=electronics
Posted on Nov 29, 2008
    Problem Solver:
  • 6 Answers
Its detecting a short somewhere.Make sure all speaker cable connections dont have stray wire shorting outputs
Posted on Jan 09, 2008
Denon AVR-3801 lights up,makes rapid clicking noises when amp tries to turn on. Clicking stops but unit doesn't play & sometimes the unit turns off. Occurred after lightning storm. What to do to fix?
Probably damaged by power surge. If you do not have experience diagnosing and repairing electronic circuits as well as having access to schematic diagrams then this is not a repair for you. Failure to replace all damaged components may result in damaging new parts.
Aug 16, 2016 | Denon Avr-3801 7.1 Home Theater Surround 7...
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
My true freezer won't defrost?
Check the defrost timer (in the base, circular knob you can turn till it clicks) If it doesn't heat up rapidly in the evaporator, there is a safety overheat device (thermistor) that may be cutting power to the heater, or there may be a fault with the heater itself. Are you sure the fans are working, and the condenser grill is nice and clean?
May 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
It won't turn on
Um, since this unit doesn't actively drive a subwoofer by design, how would THAT be a factor in its demise? Or are you using it as an amp for the sub? Then we need to know more about the sub - like its model number and impedance.
And did its predecessor also serve the same purpose? If you're overheating amps routinely I think you need to get more powerful (or professional-grade) amps.
This is not a very powerful receiver at 90wpc so using it for sub duty may be asking too much of it if you drive it too hard.
If it won't turn on with NO speakers attached, well, may it rest in peace. What model was the old receiver?
Apr 09, 2010 | Yamaha RX-V661 Receiver
When the unit is turned on the unit makes a clicking sound, nothing else. No lights, no sounds, just clicking from the right side of the unit. Sending the unit off to Sony for repair will cost $225 which...
Your unit is going into the protect mode. If this still happen after you unplug "all" the speakers, your output amp/trans are shorted/grounded... send it to Sony their price to repair is with in reason. Don't want to spend that, get a new unit. "And" check your speakers that they are the right ohms speaker and not shorted out and/or have bad wires feeding them.
Nov 26, 2009 | Sony STR-V555ES Receiver
Mod#BLU100K948A The 2 selenoids on top of gas valve click when they open (normal). Sometimes they work fine, sometimes they have a rapid clicking noise and do not open the gas valves. Furnace just runs and...
The first thing to check would be the filters in the house to make sure they are clean, then check for any blockage. One easy way of seeing if the airflow is good, just put your hands in front of a vent and see how its blowing. Your furnace has what you would call sensors, and if they sense the air flow is inaccurate or to hot inside the unit, the unit will run, but not light. Also, if it tries to relight to many times, the furnace will go into lock out and you have to manually reset it by cutting the power to the furnace. Its kinda hard to diagnose these sometimes over the pc, but I hope it helps.
Nov 02, 2009 | Honeywell Power Humidifier: Furnace...
Reciver turns on then rapidly turns off
the click is a protection switch. one of the power transistor or protection tranisitor is defective.
Aug 22, 2009 | Audio Players & Recorders
Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Mar 07, 2009 | Mitsubishi WD-62827 62" Television
HI, I have a sony v555es amp and it gives me the following error message "protector OPT.....please power off"
You might be trying to push it too hard, or you might have a short somewhere. Disconnect everything from the reciever except its power cord and turn it on. If it still goes into protect mode, then try to find a reset switch (not sure if this is on the Sony, some recievers have them). If it's NOT in protect mode, then you had a speaker wire shorting out on the back. Make sure that you don't have any stray wires when you connect the cables on the back of your receiver. It only takes one strand of copper to short out the amp section. If that doesn't work then pull the top cover off and chech the fuses out. One of them might be blown.
Tom
Jan 01, 2009 | Sony STR-V555ES Receiver
Utilizing two microphones
No, when you buy multiple wireless mics you have to select different channels per unit if you want to use them on the same stage.
hope this helps
thanks for your rating
Jan 09, 2008 | AKG (WMS40DIV444US54) Microphone
Sony STR-V555ES Receiver Logo
608 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
