9 months ago our Mitsub WS-65611 starting turning
9 moths ago our Mitsub WS-65611 starting turning itself off randomly. A repairman replaced part number 267P155010. It worked for about 7 months and started turning itself off again. Is this really the problem and is this something I could replace myself? I don't want to spend $300.00 again within the same year for a repair.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The part number you indicate is the STK-393-110 convergence IC that this set uses--it is possible it is bad again--if properly installed it should not have failed for at least 5 years.
When the set shuts off, on the front of the set engage the self check feature this set has: when the power light goes off ON THE FRONT OF THE TV press both the MENU and INPUT buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example--2 blinks, a pause and 2 blinks--this is the most common and it will repeat the code several times.
Let me know what you find---I am here to help people.
If this information helps you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 16, 2009
SOURCE:
Tip
Reset Mitsubishi WS-65611 VChip Password
Bypass or Reset Mitsubishi WS-65611 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65611 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65611 Manual Download
Bypass Mitsubishi WS-65611 Front Lock
on May 04, 2010 | Mitsubishi WS-65611 65" Rear Projection...
My tv turns on the shuts off on its own
This unit will not indicate any problem without you doing something to initiate the LED diagnostic feature. Go to the front of the set and hit the power button, when that doesn't work hold the MENU and INPUT buttons on the set at the same time for 10 seconds. The power LED should start blinking a two sequence code that will repeat six times. The number of blinks will tell the general area of the problem. As an example a 2 - 2 sequence is a convergence output problem over 95% of the time.
Jun 04, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Tip
Bypass Mitsubishi WS-65611 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65611 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65611 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Tip
Download Mitsubishi WS-65611 HDTV Manual
Have you misplaced your Mitsubishi WS-65611 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65611 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Tip
I hope that helps.
on May 04, 2010 | Televison & Video
Tip
I hope that helps.
Tip
I hope that helps.
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
