Question about Haier HLT71 7 in. Portable TV
I have this same model TV and I use it with as
I have this same model TV and I use it with the cable TV.it saids No Database.I change the cable and it still does it.Ialso trouble shoot it and I re ceived some channel with out the cable.What should I do next.
Thanks.
You probably need an RF (radio frquency) modulator to be connected between the cable and the TV. Connect the cable to the ANT IN on the RF modulator and then use the TO TV outlet OR the three RCA outlets (yellow video, red left audio channel, white right video channel) to connect to the Haier portable TV
I bought two such modulators made by TriQuest at a local surplus-type store (i.e. Big Lots) for about ten bucks each.
Incidentally the TriQuest unit also has an S-video output.
Posted on Nov 28, 2009
How do change pic. size wiyhout remote
There are several free universal TV remote control apps available for iPhone and Android. You can download and install one of these apps and select your TV model from the app's database to have full remote control again.
Aug 27, 2014 | Toshiba 40SL412U LCD TV
No sound with cable tv- AM/FM works ok
First, check all the connections to the receiver.. Make sure everything is plugged in where it should be.. Also make sure, that when you are on TV/CABLE that the surround sound is selected and that "headphones" is not.. Also check any other modes that may have been changed, (IE digital input, 5.1 channel, etc...)
Apr 05, 2008 | Yamaha RX-V661 Receiver
Why did it said on the screen that database empty.?
Sounds like main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 17, 2014 | Philips Televison & Video
Mini flatscreen hAS POWER BUT SAYS NO DATABASE..NEVER GETS A PICTURE///?
HI:
You must to setup and change the signal input to cable if you are using cable to connect the TV. IF you are using the antenna that came with the unit, you must select AIR mode. Then do a channel search to find and program in the channels.
Apr 20, 2011 | Haier HTN20R15 TV
TV says no database. Just taken out of box. Checked set up and all if fine. Will not recieve broadcast. Antennea is in and Auto scan said zero found and mode is on TV. Any help or should I return?
Since this is a new piece obtain warranty repairs from the supplier. Hope your cable is working OK with other TV.
Some times service mode adjustment needed. Only theservice provider knows the code to change the settings.
Jul 09, 2010 | Haier (PDTB7) 7 in. Portable Television
No Signal No Database
In your TV Menu select "Channel." In this list you must now select "Auto Scan" then select "Start to Scan." Wait for the scan to complete, this should solve your problem.
Aug 23, 2009 | Insignia 42" LCD Flat-Panel HDTV
Coby tv reading no database and can't locate channels
Set the TV to your the correct system ( Air or Cable) then perform a auto channel scan.
Feb 21, 2009 | Televison & Video
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
Oct 03, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Cable channels 5 and 6
not sure on this model , but check your menu and see under the setup menu if it has a band select option or tuning band. sometimes the autoprogram may pick up the wrong band. Make sure it is set correctly. I had this where it would just make some certain channels bad.
Nov 01, 2007 | Zenith A25B33W 25" TV
Haier HLT71 7 in. Portable TV Logo
495 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
