Question about Canon PIXMA MP830 All-In-One InkJet Printer
I am unable to print
"In Use/Memory" light is flashing and printer is making a clicking sound.
  • 1,992 Answers
These are the symptoms for having the phone line plugged into the wrong jack on the machine. The line from the wall should go into the "L" jack. The jack with the image of a phone is use for an answering machine or additional phone.
Posted on Nov 16, 2009
I have HP 3700n color printer.
Your print driver is set to store the print job. Unless you have updated the amount of memory that your printer has, most 3700 series do not have enough memory to do this. Check your printer settings closely. Right click on the printer icon in the control panel and select properties. Click the advanced tab and then click on printing defaults and you will see a tab called Job Storage. Make it is turned off and then apply. This should solve your problem.
Aug 15, 2014 | HP Color Laser 3700N Printer
Printer fault
The Canon Pixma IP 4000 printer has a self-diagnosing print head error notification system. Generally the "Alarm/Power" light will flash and tell you what kind of problem you might be having with your print head.
You can also run tests yourself to identify problems.
Look at the "Alarm/Power" light and see how many times it's flashing.
If it flashes orange 11 times consecutively, that means there is a print head alignment issue. Perform deep cleaning, then move the printer away from any strong light sources.
To deep clean, click the Maintenance tab in the "Printers" folder.
Then click the "Deep Cleaning" icon. You can select all colors, black, or selected colors. Click on "Execute."
If it flashes orange five times consecutively, that means there is a print head error.
Reseat the print head, then reset the printer.
To reseat the print head, make sure the printer is on.
Open the paper output tray and top cover.
Make sure the print head holder is in the center and open the inner cover. remove all the ink tanks.
Raise the print head lock lever and remove the print head.
Reseat the print head and lock the lever.
Replace the ink tanks.
Check to see if the ink is ejecting normally from the print head nozzles by running a test.
Press and hold the "Resume/cancel" button.
When the Power lamp flashes twice, release the button.
Examine the printed output.
Use the references below to compare your output to what Canon suggest is correct.
If the output is incorrect, then perform deep cleaning, if necessary repeat twice.
Replace the ink tanks if you're unable to get a good result by following the previous steps. make sure the printer is on, lift the top cover.
The print head holder will move to the center.
Press on the tab to release the tank.
Unwrap a new tank.
Make sure you can see the air hole and insert the new tank until you hear a firm click.
Repeat for the other tanks if you suspect from your print test that they have failed.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10239 - SupportDetailAct
Apr 23, 2013 | Office Equipment & Supplies
The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
The light flashing may mean more things, not just a paper jam. Could mean any of the following:
- Front cover is open: Close the front cover of the printer.
- Back cover is open: Close the back cover of the printer.
- Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
- No paper fed manual feed slot: Put the paper back in the manual feed slot.
- Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
- Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
- Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Thank you for using Fixya!
Dec 02, 2010 | Brother HL-2040 Laser Printer
My printer is saying unable to print
Try one or more of these solutions:
  • Press the fontp.gif power button to make sure that the printer is on.
  • Turn off the printer and make sure that the power cord is securely plugged in.
  • Make sure that your outlet works and is not controlled by a wall switch or timer
Lights came on and then went out
The printer's voltage may not match the outlet rating. Turn off the printer and unplug it immediately. Then, check the printer labels.
If the voltage does not match, DO NOT PLUG YOUR PRINTER BACK IN. Contact your dealer.
Only the power light is on
  • Turn off the printer and computer. Make sure that the printer's interface cable is securely plugged in.
  • Make sure that there is no packing material in the printer.
  • Turn off the printer and the computer and disconnect the printer's interface cable. Then, print an operation check page. See Running a printer operation check.
If the check page prints correctly, make sure that the printer software and your application are installed correctly.
  • If you are trying to print a large image, your computer may not have enough memory to print. Try printing a smaller image.
  • Windows Me and 98 users can clear any stalled print jobs from the Spool Manager. For instructions, see Using EPSON Spool Manager.
  • If the printer sounds like it is trying to print, but is unable to, run the Head Cleaning utility.
Paper out light is flashing or on Check EPSON Status Monitor 3 (for Windows) or EPSON StatusMonitor (for Macintosh) to find the cause of the error, then try one or more of these solutions:
  • If the fontm1.gif paper out light is on and there is no paper in the printer, load paper into the sheet feeder.
  • If the fonth.gif ink out light is flashing, a low supply of ink is indicated. Obtain a replacement cartridge of the appropriate type. To determine which cartridge requires replacement, see Replacing an Empty Ink Cartridge.
  • If the fonth.gif ink out light is on and the ink cartridge is empty, replace the appropriate ink cartridge. To determine which ink cartridge is empty, see Replacing an Empty Ink Cartridge.
Error light is on and power light is flashing
Follow the steps below.
r_1.gif Press the fontm1.gif paper button, then remove any paper from the printer. r_2.gif Turn the printer off. Check for and remove any foreign objects or pieces of paper from inside the printer. Also, make sure that there is sufficient space around the vent on the back of the printer to allow proper ventilation. Remove any objects blocking the vent. Then, turn the printer back on
May 27, 2009 | Brother MFC-210C All-In-One Printer
Canon MP780 issue on Mac OS/X
I just noticed that I had the telephone cable connected to the "Telephone" port on the back of the Fax/Printer. When I switched it to the "Line" port, suddenly the clicking stopped and the Memory/In Use light went off. Now we will see if I can Fax something. Hope this works for you too!
Sep 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Dark red prints with lines throught the picture
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Printer doesn´t print using the mangenta ink cartridge
try this :
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Dec 20, 2007 | Epson Stylus C63 InkJet Printer
Printing in blue only
try this:
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
2) Load letter size paper.
3) Click on START.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 12, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Printer makes clicking noise
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Oct 05, 2007 | HP PSC 2410 All-In-One InkJet Printer
Flashing red light on display
1st step - print a self test report Press and hold the OK button. Then press the left arrow key one time. Release the OK button. The test page prints OR Press the OK and Help keys simultaneously. The test page prints print the test pages 4 time minimum 2nd step - reset the printer If the printer is not off, press the Power button to turn it off. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the printer. Unplug the universal serial bus (USB) cable from the back of the printer, if connected. Wait 30 seconds, then plug the power cord back into the printer. Plug the power cord back into the wall outlet. Press the Power button to turn the printer on. Ensure that the memory card has been removed from the memory card slot. Make sure plain paper is loaded in the In Tray. Hold down the OK button and press the Right arrow button four times. If the test page prints, re-connect the USB cable to the printer. OR IF YOU ARE NOT ABLE TO DO SO THEN start - printers & faxes - click on the printer icon highlighted with a correct symbol ( ensure the proper printer is highlighted )- right click on the icon - properties - print test page option at the bottom of the properties screen. 3rd step - if the USB is connected to a USB Hub then disconnect it from the HUB and connect it directly to the wall socket.Make sure the USB cord is of the proper measurement as mentioned for the printer in the User Manual. 4th step - visit www.hp.com left side of the screen you shall see an option SOFTWARE & DRIVERS DOWNLOAD click on that in the next screen a tab comes up mentioning FOR PRODUCT enter PHOTOSMART D 5160 and hit enter / click on the arrow beside it choose the OS under DRIVER YOU HAVE OPTIONS LIKE - » HP Basic Driver (recommended) » HP Full Software and Driver (before downloading it uninstall the s/w & then download it )-DO THIS ONLY IF THE 1ST OPTION DOES NOT MAKE THE PRINTER FUNCTION FINE STILL ERROR PERSISTS : - replace if under warranty/service the printer in the service centre
Sep 19, 2007 | HP Photosmart D5160 InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
135 people viewed this question
old marine
old marine
