Question about Dell Dimension 2400 PC Desktop
Dell E510; computer won't turn off when using the power switch
Computer won't turn off when using the power switch. Flashing orange light.
  • 113 Answers
Replace the power supply
Posted on Nov 16, 2009
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
I shut down my Dell Dimension E510 last night and today when I pressed the on button, the computer wont turn on - not even an orange light on the power button. I tried disconnecting all connected...
Try this procedure! click here. After checking your power supply and it is working fine, put it back again into your computer casing. Next thing to do is to check your motherboard switch (power on). Look for the manual of your motherboard and look for the power on switch. If you find it then get a screw driver and short the pin using the screw driver. Be careful not to touch the other pin! But you have to check all the computer components to determine what is exactly the cause why it's not functioning. If it's not turning on your computer while you short the power switch on that means probably your motherboard fail. Other option is, in order to troubleshoot the problem of your computer you must have an extra computer with the same model and plug all your components there one by one to determine what is exactly the problem of your computer. Then you can decide what computer parts need to be replace. Have a nice day!
Dec 23, 2010 | Dell Dimension E510 PC Desktop
Hello, Last night I shut down my Dell E510 desktop - the proper way - by going to the start menu, shut down, turn power off. Then, today, I pressed the power button on the front of my tower and...
This sounds like a definite power issue. This means that the problem could range from being as simple as the power button itself not working/disconnected to the power supply being dead.
Things to try:
1. Have the side of your computer open and press the power button. Notice if any fans start to move or anything that happens.
2. Do you notice the Hard drive light flashing at all when turning on?
3. Has anyone else been using or been close in proximity to the computer that could have bumped it, causing something to come loose?
4. ONLY if you feel competent enough, check the cable connections inside the computer. Make sure to disconnect from the wall for 30 seconds and reconnect before touching any cables inside. Leaving the cable connected allows the computer case itself to act as a ground to prevent static shock.
Orange flashing light on a dell dimenson 5150 computer won't start up
The orange flashing light on the power button is an indication of power supply failure.
Your Power supply unit needs to be replaced.
Aug 11, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computer wont turn on orange flashing light on the power button
Here is a web site that may help solve your problem.
http://www.randomfix.com/2007/04/19/dell-dimension-%E2%80%93-flashing-orange-power-light/
Oct 23, 2009 | Dell Dimension E510 PC Desktop
My computer won't turn on. Orange light flashing......
hi,
this is smps problem replacement power supply that is smps will solve it out......it will cost around 10-30$
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Dell Computers & Internet
Computer won't turn on
A flashing yellow power LED is an indication of a failure in the power supply. If under warranty, Dell should be replacing it. If out of warranty, then a 400/450 Watt ATX power supply should resolve the issue.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182021
Apr 06, 2009 | Dell Dimension™ E510 PC Desktop
Dell Dimension 2400 PC Desktop Logo
106 people viewed this question
Alun Cox
