I have a mitsubishi tv that cuts off after about 30 seconds and lamp light is red but i replaced lamp 1 week ago.
    Scholar:
  • 39 Answers
Hi
Well if you have replace the lamp just recently what could be happening here is that your ballast is not working properly and is to week to keep you lamp running,The definition of the ballast:
How It Works
The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp.
The lamp works with the ballast to project light into a light engine that separates the colors of the light, then recombines them with an image.
The image is then reflected on the back of the TV and then onto the screen.
If the ballast is to weak it will no have enough power to send the 15,000 volts to get the lamp ignited
You can get more check this websites http://www.partstore.com/Part/Samsung/Samsung/BP4700029A.aspx?s=froogle or http://www.discount-merchant.com/SearchResults.asp?Search=Mitsubishi+Ballast?click=52978
Please keep us posted
Samuel
Posted on Nov 16, 2009
Wd-52627 tv turns off on its own,then solid red light
I just replaced my lamp and it worked for a day. TV only gives me sound. Black screen. Light goes from green to red lamp light after about 30 seconds. Did you get a fix?
Jun 04, 2014 | Mitsubishi WD-52627 52" Television
Mitsubishi WD-65733 Red light on Replaced lamp twice
I'd just replace my lamp just three days ago and the problem still
exsist
Nov 10, 2013 | Mitsubishi WD-65733 65" HDTV
What's your problem?The tv comes on for 1 second and turns off and the red lamp light is on
Replace the lamp. The red lamp light is indicating an issue with the lamp. You can get the replacement lamp with installation instructions from www.tvrepairworld.com
Oct 19, 2012 | Mitsubishi Televison & Video
I have a mitsubishi dlp WD-65733 and it went out on me a week ago. when I power it up i get only the green light above the timer. when i hit the reset button in the front i hear a click in the back and the...
It seems problem in power supply board that got few electrolytic capacitors leaky and causing problem. It does not look like lamp issue.
Let me know are you handy with electronics stuff repair and can replace parts in circuit board?
Thanks.
Apr 06, 2011 | Televison & Video
Hi. i just replaced the lamp in my t/v and after watching for about 30 minutes the t/v turns off with the red lamp indicator light. if i wait 30 seconds and press the power button it turns back on but only...
that wouldn't be needed to do. mostly it means if it's not the lamp it's a hardware problem call the mitsubishi parts 1-800 number they can fully further help you but when they tell you what part you really need look on ebay for the part and save some money
Jan 08, 2011 | Mitsubishi WD-57733 57" HDTV
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Sep 03, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
