Question about Microsoft Windows Vista Ultimate Edition
Windows vista in windows vista,new updates available pop up appears, when clicked on it it shows, update available for HPw 2207 wide lCD monitor, when tried to install, it shows installing window, then it show update failed, gives the error 80070005. tried uninstallin and installing driver for monitor, did not help.
    Genius:
  • 1,601 Answers
1. Disable Windows Update
a. Click on start
b. Click on all programs
c. Click on accessories
d. Click on Run
e. Type services.msc and press ok
f. Right click on "Windows Update"
g. Click on stop (Windows Update is now disabled)
2. Rename Software Distribution folder
a. Navigate to: C:/Windows/
b. Find the folder named: “SoftwareDistribution”
c. Rename that folder to something like “SoftwareDistribution.old”
d. Create a new folder called “SoftwareDistribution”
3. Enable Windows Update
a. Click on start
d. Click on Run
f. Right click on windows update
g. Click on start
If you are unable to find Software Distribution Folder, follow these steps before #2 above.
1. From the explorer window press the Alt key to view the file menu.
2. Click Tools
3. Select Folder Options
4. Select the View tab
5. Select “Show hidden files and folders”
6. Remove the selection from “Hide protected operating system files”
7. Click OK
Restart your PC and you should be good to go!
Posted on Jan 09, 2008
  • Thomas Christopher
    Thomas Christopher Jan 10, 2008
    Did you get this resolved. If so please rerate as FIXYA. If not please let me know so I can help you further.
    Thanks
6ya staff
SOURCE:
What is jucheck.exe? It keeps trying to acess my computer. I select NO and it pops back up.
The jucheck.exe is the Java update verification process. This process will check on the internet for available updates for the Java software installed on your computer. If updates are available, it will notify you and/or manage the download and install of the updates. You should leave this process running in order to keep your Java up to date.
When there is a notification for new update, a tooltip ballon appears.
To install new update click the notification window.
Note: If you are on Windows Vista or Windows 7 operating systems, then you will see User Access Control (UAC) consent prompt.
The consent prompt is seen when a user attempts to perform a task that requires a user administrative access.
Click Continue button to install new Java update.
Jul 30, 2011 | Computers & Internet
Flat screen monitor almost works
check for the specifications of your PC's video card with the screen.
problem maybe at something else rather than the monitor.
try booting it on SAFE MODE.
Feb 28, 2008 | Mag Innovision InnoVision LT765 17" Flat...
I am using VA1903wm LCD monitor from Viewsonic. It worked well at its non standard resolution of 1440*900 when used with Windows Vista. i had to upgrade to Windows 7 Enterprise edition and this resolution...
Update your graphics card drivers to the newest ones available. That is typically caused by having the default windows driver for your graphics card. If it is a Nvidia gpu get the drivers from them, itf its an ATI/AMD get them from AMD Game. If it is neither of those Intel does some graphic cards, if its not an Intel one go to the computer manufacturers website and find your model to get drivers for it.
May 17, 2011 | ViewSonic VA1930WM LCD Monitor
When i m try to install my bluetooth drivers then windows stopped my device and show the problem of 'code 43'. So tell me what is code 43 ? And how cani cure it.
To resolve this problem, obtain the latest service pack for Windows Vista. Follow these steps:
1. Click Start vistastartbutton.jpg, click All Programs, and then click Windows Update.
2. In the navigation pane, click Check for updates.
3. After Windows Update has finished checking for updates, click View available updates.
4. Click to select the check boxes for the updates that you want to install, and then click Install.
This should solve your problem. If not contact me without hesitation!
May 11, 2011 | Microsoft Windows Vista Ultimate Edition
How to install
How to Install a Vista Ultimate Language Pack
Windows Vista Ultimate offers a number of enhancements, called"Extras," that provide additional exclusive capabilities to users.Vista Ultimate Language Packs are Extras that make use of the Multilingual UserInterface (MUI) to enable menus and text in different languages.
1.Log into Vista. Make sure to log in as theuser for which you want to apply a Language Pack. 2. Start Windows Update. Hit the Start button, and type"Windows Update" in the search field. Click on the Windows Updateapplication that is highlighted at the top of the window, under"Programs." 3. Run Windows Update. Click on"Check for Updates." The window will then indicate whether or not newupdates are available. Click on "Show Available Updates." A dialogwill appear showing a list of available updates, including Windows UltimateLanguage Packs. 4. Install aLanguage Pack. Select a language, and click "Install." Note thatLanguage Packs are large downloads of approximately 200MB, and require as muchas 1.2GB of storage space. Set aside at least 30 minutes for the installation.Accept any User Account Control (UAC) prompts that appear. 5. Apply the LanguagePack. Once the Language Pack has downloaded and installed, go to"Start," "Control Panel," and then double-click"Regional and Language Options." Select the "Keyboards andLanguages" tab, then choose the new language in the drop-down list under"Choose a display language."
Nov 11, 2010 | Microsoft Windows Vista Ultimate Edition
How can i update my window 7 ultimate edition
To ensure that Windows 7 is up to date, follow those steps.
  2. Select "All Programs"
  3. Click on "Windows Update"
The follow window will appear on your screen:
The Windows Update applet allows you to check whether updates are available for your system. In the picture above, there are no new updates available as is indicated by the white checkmark inside the green shield and the text next to it.
If new updates are available for your system, the shield will turn orange with a black exclamation point. You will be presented with the option of installing those new updates.
As you can see on the left side of the Windows Update, there is a menu of choices.
  • Check for updates - allows you to initiate the update process to see whether new updates are available
  • Change settings - choose settings that affect what Windows Update will do with new updates (download only, download and install, never check for updates)
  • View update history - view all installed updates and their status
Note that it is possible to uninstall an update in case it causes the system to become unstable.
If you have any more questions, please feel free to ask!
Sep 19, 2010 | Microsoft Windows Vista Ultimate Edition
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
Cannot install: HP Compaq WF1907 Wide LCD Monitor Update.
I found in the folder of Hp the file that does the " UPDATES".
So, thanks for the offer to help me, but all is well now with me and the Hp UPDATES.
Regards
Frank
May 19, 2009 | HP Compaq WF1907 Monitor
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Microsoft Windows Vista Ultimate Edition Logo
121 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
