Question about Intel Motherboard
I have an HP Pavillion a1250n which has a MS-7184 V1.0 that will not boot. When turned on the HP Invent logo screen appears with thw following at the bottom:(Esc=Boot Menu)(F1=Setup)(F10=System Rocovery)(F12=Boor from LAN). But nothing happens when one of these fuctions is selected. How ever if the Esc key is held down while power is turned on "Loaading Boot Menu...." appears but goes no further; and when F1 is held down durinf power up,"Entering Setup..." appears but goes no further. I tried booting with every thing disconnected and still nothing. HELP!
  • 3 Answers
I have the exact same problem with the exact same motherboard. However, disconnecting everything, including the hard drive, all cables from the motherboard except the CPU fan, and pulling all cards still results in the HP boot screen freeze. It makes me think it might be the motherboard itself. Removing the CMOS battery and clearing the CMOS doesn't do anything either.
Posted on Mar 26, 2013
  • 3 Answers
It sounds as though you might have a problem with BIOS.
You should remove your motherboard battery (little round silver disc) and if you can find (or Google motherboard model#) the CMOS reset jumper, you can remove the battery for 30 seconds and put it back in and reset the CMOS, then see if it boots. If it doesn't, you might need to flash the BIOS, which is not recommended unless you know what you are doing.
Posted on Nov 16, 2009
  • Mp3sponge Jun 14, 2011
    Hi there , sounds more like a hard drive or DVD-RW drive has failed. This happens often and is pretty common to lockup on the 'post' screen. Disconnect the hard drive first and see if the blue HP logo post screen operates like normal and allows you to enter bios at that point. If it does, you found the problem!.
    1. Use the thumb screws on the side panel and slide back the case
    2. Locate the hard drive (depends on model where its located) and disconnect both IDE ribbon and power connect (molex) .
    3. Startup pc and press F1 to enter bios (this should work normally now)
    If you've gotten this far, just replace the drive, install your recovery set that you probably forgot to create while the computer 'was' working, or call HP for another set (should cost you about 40$). Another option is to install a clean copy of windows, but Id suggest having a tech do that for you. Drivers can be a pita (pain in the a**).
    have a good one!
    Jay.
  • ab Mar 26, 2013
    Further research reveals that the ms-7184 commonly has bad capacitors. I even see capacitor kits for sale on ebay for this motherboard. So the problem is most likely the motherboard.
Msi ms-7184 ati rs482 socket 939 motherboard stuck on hp invent
Hello Sammy, try pressing and holding the power button to turn off the computer. Unplug the computer from the wall and wait 10-15 sec. Plug it back in and power it on. See if that works.
Dec 30, 2013 | Computers & Internet
MSI MS-7184 keyboard usb and ps 2
Sounds like your processor might be heating up too fast. I would take the computer apart, clean it removing all dust from the fans, check to see if the fan is actually spinning and check to make there the silicon glue has not dried up. It could also be that your power supply isnt supplying enough power but if you haven't added any devices that wouldn't be the issue.
Nov 21, 2013 | HP Amethyst motherboard MSI MS-7184 Socket...
Ze4610 won't boot past HP logo
The hard drive has issues, the next step is to have it tested for possible replacement.
Jun 05, 2012 | HP Pavilion ze4610 Notebook
WHEN I POWER ON MY DESKTOP COMPUTER,BLUE SCREEN APPEARS TOGETHER WITH THEY HP INVENT LOGO.IT DOES'NT BOOT.
Hi.that may mean your pc has crashed.what kind of operating system where you using?dont know much about xp but windows 7 automatically recovers from that.try using the recovery disc for that operating system
Jan 25, 2011 | HP Computers & Internet
I want to restore my laptop to factory settings its an hp pavilion dv4000
  • Using the recovery partition
    • 1 Turn on your computer and insert your recovery disc. Press F10 during start-up to open the console. This opens up the HP recovery console.
    • 2 Click "Next" on the screen that appears.
    • 3 Choose whether you want a nondestructive recovery (one that keeps your files in place) or a destructive one (one that erases your disk and rebuilds your system to factory defaults). If most of your files aren't corrupted or are still usable, go with a nondestructive recovery. Otherwise, perform the destructive recovery.
    • 4 Follow the instructions on the prompts that appear to restore your HP Pavillion.
  • Using recovery discs
    • 1 Turn on your computer. Press F1 at the first logo screen to enter the BIOS menu.
    • 2 Move to the Boot Options section of the BIOS menu. Look for the Boot Priority menu.
    • 3 Set the Boot Priority option to booting the CD-ROM first.
    • 4 Insert the first recovery disc into the HP laptop. Then press "Enter" on your keyboard to save your settings and exit. The computer will then reboot into the recovery console.
    • 5 Follow the instructions on the prompts that appear, to restore your laptop.
  • Jan 01, 2011 | HP Pavilion dv4000 Notebook
    Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
    few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
    Jul 10, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
    My hp DV5 Pavillion Laptop keeps showing Hp invent on booting and when the hp screen appears the system hangs and never gets beyond it. Please what do i do as the Laptop is still very new slightly over a...
    this is only bios issue..im sure 101% find the person who can update ur laptop bios with programmer ... no need open compelete laptop bios location is on the bottom ... if u need bios file i can send u .. this is my email sim4182@yahoo.com
    Jun 20, 2010 | Computers & Internet
    HP pavillion dv2700 clicking noise, black screen
    try to run the hdd test in the bios page and see what it says. if it says no ide device found, try to reseat the hdd.
    Apr 26, 2010 | HP Computers & Internet
    Hp ms-7184 AMD base when windows is about to
    ok this can be caused by a LOT of things but easier first check your cdrom/dvddrive. make sure clean and pretty.
    did you reformat the drive?
    what operating system?
    Sep 12, 2009 | HP Computers & Internet
    My Hp Pavillion laptop dv2214tu doesnot boot beyond the HP INVENT logo page. I tried performing the Primary Hard Disk check as stated on the HP Support site but its not happening.I also reseated the RAM...
    Unscrew your Laptop HardDrive bay and remove your harddisk first, then try to boot your system wthout the Harddisk inside. If it Boots past the HP Invent Logo Page, then your harddisk is the one that is faulty, if still doesnt, get another good, working RAM, apart from the one in your system, and use it to test your laptop...making sure that the harddisk is still not inside...then if it boots insert your Harddisk back with the new RAM, and restart your system.
    If in the first case it boots (i.e wihout the harddisk inside)...then it means your harddrive is faulty, just retrieve your file on it and get a new one.
    If in the second case it works (i.e with a new external RAM) then just change your RAM instead.
    Jul 09, 2009 | HP Pavilion Notebook
    Intel Motherboard Logo
    773 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
