Question about Ovens
Oven that refuses to oven
Hiya, my oven won't heat up, its a diplomat single electric oven, and when i switch it on the fan comes on but nothing else
    President:
  • 1,314 Answers
What were you doing the last time it worked baking broiling self clean if the clock isn't on turn the breaker off for 5 seconds then on reply to me with make and model number from the serial plate on the door if that doesn't fix it but don't rate me till we are done
Posted on Jan 09, 2008
When turning on the oven it refuses to heat! The inside light and fan both come on however the oven does not get hot. This problem occurred overnight it was fine one day and went on strike the next. I...
If the fan is working o/k, then it is going to be the oven element that is faulty. This is located behind a removeable cover at the rear of the oven compartment.
Oct 27, 2010 | Smeg SE210X/1 Stainless Steel Electric...
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Fan comes on in the oven but the oven does not heat up, not sure if I have messed with the timer
Hi.
If the fan is working o/k, then there is nothing wrong with the timer, you need to replace the fan oven element, this will solve your prob.
Please rate my solution.
Thanks.
Sep 05, 2009 | AEG B3101-4 Electric Single Oven
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Manual for a Diplomat Select 620 single oven
Sent the manual to you Tuesday the 18th.
Mar 09, 2008 | Ovens
AEG B2100 Not heating up - light does not turn on
Main selector switch may have burned contacts.
Nov 07, 2007 | AEG B2100-4 Electric Single Oven
Ovens Logo
259 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
