Question about Insignia IS-LCDTV32 32 in. Television
No signal from coax input on 32" lcd
I have a 32" Insignia LCD TV that gives me a "no signal" from the coax input. All other inputs appear to work properly. The settings have been checked and are correct.
  • oji1906 Nov 16, 2009
    Thanks.. However, the fix didn't work. I don't have a PVR to pass through. I'm using a cable directly from the wall outlet. The closed captioning was off.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Due to two things that will cause the No Signal message to come up are – no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No Signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the No Signal message.
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts.
Try using Component cables if this doesn’t make a difference. After using components cables your issue will be resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 16, 2009
My insignia 42 inch tv screen seems washed our all of the sudden. Any idea why??
If you are using a box for signal to rear inputs and not the coax in try unplugging both the set and the box--wait and plug back to see if both will reboot.
Is the issue the same when using a DVD etc connected to one of the rear inputs?
Apr 02, 2012 | Insignia 42" LCD Flat-Panel HDTV
Tv will not stay on comes on for 1 second and goes off
check input connections..bad signal or bad tv...u can also try using another tv to check input signal...and u will know if tv is bad gl
Sep 07, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
How do i connect my pc to my tv
Used the VGA cable came with ur computer monitor,used that VGA cable plug in VGA input it the tv and plug it other end to the computer video card.Used ur tv remote look for a input button pushes look for the mode computer signal in the tv like input 1,2,3..so on.
Feb 12, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
32 inch LCD sharp tv switches audio from mono to sterio every 4 to 5 min
When you are connecting this television to a signal source with a coax cable this happens. The solution is to connect with an RCA/composite cable instead and utilize the television's inputs instead of using input tv.
Jan 16, 2011 | Sharp LC-32SB24U 32 in. LCD TV
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
HOW DO I CONNECT A VCR AND WHAT DO i SET THE INPUT ON.
If you have connected using the coax (aerial) ten the problem will be that the vcr is analogue and the tv is digital(if you have an older digital tv it should have an analogue tuner so you can set it to analogue and tune to the vcr) I suggest using a scart cable from the vcr to the tv, then you just press av on the remote(on some you can just change the channel down from 1 to the av inputs).
Jan 02, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
Tv with out coax inputs.
you can run it through a cable box or vcr that has a coax input and rca output.
Apr 14, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
No signal
Try this.
1. Take note of what input you are using to your television. AV1 or AV2 or Component 1 Component 2.
2. On the remote, toggle the input selection to corresponding input for your DVD.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
Insignia IS-LCDTV32 32 in. Television Logo
397 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
