Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Just replaced lamp and picture has rolling color lines through it. What is causing this? This was happening prior to lamp replacement as well.
  • tomd223 Dec 09, 2009
    I had a tech from a local TV repair shop tell me that the rolling lines are from a board going out. The boards are no longer available but can be rebuilt by Mitsubishi for $700 in 4-6 weeks. Is this the same thing you are telling me to replace the capacitators on.
  • Mitsubishi Master
  • 5,138 Answers
Call Encompass Parts 1-800-638-3328 or visit their website online. it could be your DMD board or check DMD Fan if it is not running replace it also remove any and all dust and Dirt if you see any and clean off optical lense make sure none of air ways are blocked with dust or dirt.
Posted on Nov 16, 2009
Testimonial: "This gave me a place to start with. When going to Encompass though they don't carry parts for Mitsubishi products."
  • ladywinn
    ladywinn Nov 19, 2009
    Here are some more Places for you to try UED 1-800-648-6657 and call PTS 1-800-844-7871 Also Look on E-Bay I have found good prices on Parts that I need for TVs in shop for repair. Ck power supply for Bad capacitors 1000uf 25v most of the time their will be 4 of them replace all of them.
How do I fix?
Probably the replacement lamp is not correctly aligned. HOWEVER, if the band is not on the bottom, but is surrounded (above and below) with good picture, the cause is in the RED color circuitry usually the 'convergence' section. This type of failure is often due to a failing electrolytic capacitor. Repair is problematic and may be in the integrated circuitry.
Jul 23, 2014 | Sylvania Osram Replacement Lamp & Housing...
Square "zones" of bad vertical lines in picture lines appear white Replaced color wheel, remained same
it is not correlated with color wheel
you can do following these:
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Mar 09, 2014 | Samsung SELECT HLR5656WX/XAA Rear...
Every other line of resolution flashes black
the fan like or high pitched sound may be a color wheel--if you unplug the set and remove the lamp you can look at it--any pieces of the colored plastic wheel missing or broken?
Apr 03, 2012 | Samsung HL-R6167W 61" HDTV
Mitsubishi wd-62525 sound will come on but no picture.
Your tv would turn on if you replace the only two 3300µf@16v capacitors on the power board . You wil notice they are bad by the way they bulge up at the top and may be leaking electrolyte a little from the tops . But the rolling lines would still remain but much less noticable.Then other symptoms will eventually appear. Truth is many many many many other capacitors need to be replaced inside the electrical chassis. Your TV would need to go to a repair shop that is expierienced in that repair because it is so extensive.
Oct 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
YELLOW AND BLUE SQUIGGLY LINES ON THE RIGHT SIDE OF THE SCREEN
Hi Fkanode.
The failure(s) in your TV is related to a part called light engine or optical block and Sony TVs are known for these kind of failures with the video showing with different colors or lines.
Check the link provide for more info or if you would like to try fixing the TV yourself.
Let me know if you would need further assistance.
Mar 07, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Motorized sound and picture quality poor and jumpy
your husband is correct it is most likely your color wheel very common and it will effect the picture. what will happen soon is your tv will not turn on. The cost is two possiablities. color wheel replacement 225,00 part is 80,00 complete light engine in rear cases cost is 650.00 dollars . I hope this helps
thanks doctor video leadingedgeeletronics since 1987
May 04, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Color Lamp
It is not as simple to replace as a bulb. This is a picture tube, and for a novice, no play it safe and have a tech have a look first. Just because the picture tube does not light up, does not mean the tube is bad. There could be several things in the solid state circuits that could cause this problem. Good Luck
Sep 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Intermittent picture
Most likely your lamp needs to be replaced as that will cause the intr. picture issue. The color wheel will also have to be replaced. The color wheel is only available with the light engine which is part# 263223 and the lamp part #260962
Mar 05, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
