Balance Knob Technics SA-GX190
The balance knob on my Technics SA-GX190 isn't working correctly--in the center position, I'm not getting volume and can't hear all tracks. No problem with speakers. Solutions?
  • 336 Answers
Sounds like a dirty pot. With the receiver off turn or slide it back from one side to the other. Test it, if its a little better you can clean it with a little (a drop or two) of wd40, You will probably need to remove the cover to get to it.
Posted on Nov 16, 2009
Older technics SA-GX100 sometimes left or right speaker will not work until volumes is cranked up
buy some turner cleaner or electrical contact cleaner(radio shack) with the power off take the volume knob off spray into the area where the knob goes(the little metal post) turn the post back and forth with your fingers or needel nose plyers several times (over time dust and dirt build up makes a bad connection) you may have to do this a couple of times dont worry this stuff drys realy fast this should do the trick
Sep 06, 2014 | Panasonic Technics Sa Gx100 Amplifier...
Technics SUV-10X. I am looking for the Balance Knob
It is an amplifier, not a turntable.
Have you asked Technics?
Jan 18, 2013 | Technics Audio Players & Recorders
Audio braks when volume 1/3, permanent
If with another position of the volume buttom the sound is normal, maybe the problem can be dust or something jammed between volume buttom and its knob. Try to carefully pull out the volume buttom from the unit and then clean its internal part with some neutral lubricant as well as the knob where it it is fixed.
Sep 19, 2010 | Technics SA-DA10 Receiver
I turned the stop motion knob in order to wind a bobbin and the knob fell off! I have tried to put in back together but now only the knob will move not the balance wheel. As as result the clutch will not...
There should be a washer that fits over the balance wheel, if you dont put that back on the machine wont work.
Check around and see if it fell off when you removed the knob, or check to see if it is stuck inside the knob.
The washer is about 1" in diameter with a couple little tabs on it.
It will only work when installed correctly so if at first you fail just turn the ****** over!
Aug 26, 2010 | Janome L-344 Mechanical Sewing Machine
Hi: I have an sa-gx technics amplifier and when I turn it on I can hear the sound
Try to turn it on with volume knob at zero position. That might work well.
Good Luck.
Flavio/Brazil
Jul 28, 2010 | Audio Players & Recorders
Need an operating manual for JVC KD R 506 car radio
Follow these steps to adjust the balance settings
Press Menu key for 2 seconds
Turn Volume knob till you reach Audio
Presss Volume knob
Turn volume know till you reach balance settings
Turn volume knob left or right for balance
However, you cannot change the bass/treble settings as this is preset with the EQ settings available.
Jun 13, 2009 | Car Audio & Video
Need to replace the volume knob switch...
Sorry we have no parts locator service here at this website.
Jul 06, 2017 | Computers & Internet
Fade and balance
Bass, treble, balance and fader are all accessed by pressing in on the volume control knob. Press and release repeatedly to select the various functions, then turn the knob to make adjustments. An owner's manual can be found here: http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13668&langId=-1
Jun 10, 2007 | Jensen CD4610 CD Player
225 people viewed this question
 Grubhead
Grubhead
