Question about Casio TK 6000L Cash Register
Casio TK-7000, changing Tax rate for PLUs
Hi there, my bar in France uses Casio TK-7000 tills. We have recently had a change in tax in France on certain items (food and non-alcoholic drinks) from 19.6% to 5.5%. I would like to know how I change the tax rate on the associated PLUs.
Also is it possible to change so that certain PLUs have two tax rates eg a drink that costs 6.50€, 5€ is taxed at a rate of 19.6% and 1.50€ is taxed at 5.5%.
The manual is no help at all
Many thanks in advance
Manual for Casio MS-120TE Calculator or how to program exchange rates
press AC
press RATE SET, hold for approx5 secs till you see "tax" "%" displayed
type in new rate (say 20)
press RATE SET (to confirm 20% as new tax rate)
Done
Oct 19, 2009 | Casio Office Equipment & Supplies
Tax rate on sharp xe-a102
To change/program the tax rate, use the following procedure:
  1. Turn key to Z/PGM position
  2. Press 8
  3. Press #/ST
  4. Press A
  5. Press #/ST
  6. Press 2 (Auto Tax)
  7. Press #/ST
  8. Press 097500 (9.75%)
  9. Press #/ST
  10. Return key to normal mode
This procedure should program your tax rate at 9.75%
  1. Press #/ST
Jul 27, 2009 | Casio TK 6000L Cash Register
Casio TK 2100 - Change the Tax Rate, Have a 50% discount Button,
Manual here:
http://www.cashregistergroup.com/acatalog/Casio_TK_2100_instruction_manual.html
Jul 14, 2009 | Casio Parts Cash Register PC Desktop
Programming sales tax
You're right, the manual is terrible but I think I got it worked out...
Turn to PGM mode.
  • Press 3 then subtotal button.
  • Press subtotal button again.
  • Then endter tax rate (if even enter two digits 05 for 5%, if more enter 4 digits like 5.75 *5+.+7+5 for 5.75%) and press ca/amt tend button
  • Press 0 and press ca/amt tend button
  • Press 0125 and press ca/amt tend button *this is for rounding/tax table code not positive on this one but looks like the right entry for "add on" tax
  • Press sub total button
This should change your tax
Apr 07, 2009 | Casio TK 6000L Cash Register
Casio fr-2650 plus calculator
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Apr 05, 2009 | Casio FR-2650Plus Calculator
Casio TK-2100, Change the departments.
Hi.
All the settings require different codes. What did you want to change, price, tax status etc?
Mark
Feb 03, 2009 | Casio Parts Cash Register PC Desktop
Casio tk-2100 change tax rate to 15%
Hi. That's an oldie. I might have some info kicking around in storage for the 2100 if you are still having trouble. Just let me know.
Mark
Jan 20, 2009 | Casio Parts Cash Register PC Desktop
Need to change tax rate on a Casio tk-6000/6500 register
turn key to PGM
1 CLK# 3 SUBTOTAL 0125 SUBTOTAL 8.75 CASH 0 CASH 5002 CASH SUBTOTAL
turn key to REG1
8.75 is my tax enter your tax instead. make sure to put the decimal point.
Oct 28, 2008 | Casio TK 6000L Cash Register
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
66 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
