Question about Acer Aspire 3680 Laptop
Bootmgr missing on a acer 2930z. Havve no reboot disc etc. plz help...
  • jami-dodger May 11, 2010
    What Os is on it? Vista, XP
    Guru:
  • 261 Answers
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Posted on Dec 24, 2010
Bootmgr missing
You need to have a operating system's disc because you would need to load the bootmgr from it. Insert the disc and start your computer. Your computer will ask you to boot to the cd. Hit enter and run a start up repair so that the missing system file will be added.
I hope this helps!
David
Jun 22, 2013 | Dell Vostro 1014 Notebook
Solusi untuk BOOTMGR is missing pada acer aspire one happy2 N578Q
This sounds like a hard drive failure, try your recovery disc if available, if no change! have the hardware checked for possible replacement.
Oct 26, 2012 | Computers & Internet
My laptop says bootmgr is missing and i dont know how to fix
First make sure that all usb devices are unplugged and remove all cd's or dvd's or sd cards etc.
If you are running Windows 7 or Vista you can try do a repair by hitting F8 while it boots and then select repair. If this does not work you will need a install disc. If you have Windows XP you will need an install CD to do a repair. I have attached a few links that may help explain in detail. Thanks for using fixya.
bootmgr-is-missing-error-while-trying-to-boot-windows-vista/">http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
May 15, 2011 | Acer Aspire 3050-1733 Notebook
Acer aspire 5532, windows 7, 64 bit. No backups or recovery disks. Created a repair iso disk to access (from online torrent) x partition has set up files. Recovery shows no OS. D drive has been...
Just find a generic Win 7 install disk (borrow one from a friend) and use it to install - the key for it should be on the sticker. This will fix everything else, including the botched install problems. Later download and install its drivers yourself from here
http://support.acer-euro.com/drivers/downloads_gd.html
May 07, 2011 | Computers & Internet
Bootmgr is missing
Fixing the "BOOTMGR is missing" error isn't too hard; here's how.
The day before yesterday I was testing out a program with several system utilities built in. One of its components left my computer in a bit of a mess - no icons anywhere and other assorted woes. I had set a system restore point before I ran the program, so I thought I'd do a system restore. System restore gave me a message that it couldn't restore my files. I decided to restore a disc image I had made a short while back. When I booted up the computer I got a message:
BOOTMGR is missing
Press Ctrl+Alt+Del to restart
I stared at it the white letters on the black background for a few minutes, while the cursor blinked back at me. After some searching (on another computer) I had some solutions.
Barring any hardware errors, here's how to fix that error:
  • Insert your Windows Vista or Windows 7 disk into your DVD player and restart your computer.
  • The next screen you see should have the Language, Time and Currency and Keyboard boxes.
  • In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
  • Click on "Repair your computer"
  • Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
  • Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
  • You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
  • When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
  • At this point, you can remove the DVD, reboot and everything should be working.
Two sites I found helpful are BOOTMGR is Missing at about.com and cyberstorms How to fix "BOOTMGR is missing" in Windows Vista
If the method outlined above doesn't work, try Solution #2 at the cyberstorm link.
Oh, restoring the disc image went fine and all is well. All my data was backed up (somewhere other than the hard drive Windows is on) so that was one thing I didn't need to worry about. Windows Vista and Windows 7 are the only Windows operating systems where this message appears; XP users don't have to worry about this one.
Feb 18, 2011 | Acer Computers & Internet
Bootmgr missing Acer aspire 5732z
You can try to Repair your Windows using the Windows installation CD (for Repair choose R when prompted). You can let the automatic repair to try and fix it, if that doesn't work upon restart reboot and start the Repair again, but this time select Command Prompt or Console and put in "bootrec /rebuildbcd" without the quotes. If you don't have Windows installation CD you can try downloading Hiren's Boot CD and try to fix the bootmgr with the utilities from the disc: http://www.hirensbootcd.org/download
Feb 09, 2011 | Acer Computers & Internet
When i turn on computer says bootmgr is missing
Hello I believe you have some system configuration problems or perhaps a damaged boot sector. A sure fix would be to boot to the installation disc and perform a repair installation. If no luck, boot to a DOS disc and type in fixmbr. Then attempt the repair installation of windows. Hope this helps.
Nov 28, 2010 | Acer Aspire One AOD250-1924 Netbook
Ok i was tryin to reboot my laptop but now all im getting is bootmgr is missing i dont know what to do can some one help me with this please
You can try to Repair your Windows using the Windows installation CD (for Repair choose R when prompted). You can let the automatic repair to try and fix it, if that doesn't work upon restart reboot and start the Repair again, but this time select Command Prompt or Console and put in "bootrec /rebuildbcd" without the quotes. If you don't have Windows installation CD you can try downloading Hiren's Boot CD and try to fix the bootmgr with the utilities from the disc: http://www.hirensbootcd.org/download/
May 13, 2010 | Acer Aspire 3050-1733 Notebook
Missing bootmgr
sir try copy the bootmgr to other computer.
Feb 09, 2010 | Acer Aspire One PC Notebook
Acer ferrari 3200 pc notebook problem
Hello. Vista needs a repair. You will want to start by putting in your own vista disc or borrowing one from someone. If your laptop isn't booting from the disc, then enter the bios (by hitting f2 or f12 usually) at bootup and select the DVD/CD rom drive to boot first. When the vista disc loads you will want to select recovery tools. Then select "startup repair". That should fix your problem.
Apr 12, 2008 | Acer Ferrari 3200 Notebook
Acer Aspire 3680 Laptop Logo
245 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
