Question about Canon LaserClass 2060P Plain Paper Fax
Location Number We would like to have the proper number on documents faxed out how do we program the right number in the fax machine?
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
My fax machine MX532 won't let me send a fax though the machine
This is probably an issue for the receiving fax. Try this:
1. Find a piece of paper and write fairly large:
Call me if you get this
Your name
Your phone number
2. Send this to a different fax machine at a different company and location. If it works, then attempt to send it to the same fax you initially attempted.
- If it works then your document may be too large and you will have to send it over a couple pages (or less at a time).
- If it doesn't work then there is a compatibility issue with either your or the receiving end fax machine. You will have to find an alternative fax number to a different model fax machine. Don't expect the company on the other end to just change out their fax machine but they may have another model at a different phone number.
Another alternative - you can attempt to scan your documents and send them by email but check with your and the receiving destination security departments.
Best wishes,
Aug 25, 2016 | Canon PIXMA MX532 Wireless All-in-One...
How do you fax papers?
Make sure the fax machine is properly installed with an operational phone line. Put the papers in the fax machine (ensure they are facing the proper direction). Dial the number you want to fax to, ensuring you have the proper codes for external lines and long distance calls if required. Push the start button. The machine will scan your documents, dial the number, and send the faxed documents when a connection is made.
Mar 11, 2015 | Office Equipment & Supplies
  1. Make sure the fax machine is plugged into a power source and also plugged into a working phone jack.
  2. Turn the fax machine on.
  3. Obtain the fax number of the destination fax machine.
  4. Gather the documents you want to send and put them in the order you want them to be received.
  5. Fill out a separate piece of paper called a coversheet with the recipient's name, fax number/phone number, your name, your phone number, a short message and number of pages (including coversheet).
  6. Lay the documents face-up in the fax machine feeder tray with the coversheet on top
  7. Dial the recipient's fax number - put 9 before the number and area code
  8. Press the "fax" or "send" button, depending on the particular fax machine model
Nov 17, 2014 | Office Equipment & Supplies
I need to program are fax machine to have are fax # on documents that are being sent to other fax machine's
1. Press <function> then "Down Arrow" on the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" on the <start> button until [OWN NUMBER SET] is displayed.
3. Press "Right Arrow" [ENTER FAX #] will display.
4. Enter your fax number with the number keys (max. 20 digits). To insert space, press <#>, to enter "+" press <*>. To clear a mistake press <speaker> button.
5. Press <start/memory> button.
6. Enter your name by pressing number keys for each letter. Will display the capital letter for each of 3-4 letters to number, then number, then the lower case letters for each press. Use "Right Arrow" to go to next letter, if using the same number key (IE: B to A uses 1, use "right arrow" to go to next space). The #1 will give a space between words. (Max. 24 Characters).
7. Press <start/memory> [DATE&TIME SET] will display.
8. Press <stop> to exit.
Mar 19, 2010 | Sharp UX-B750 Inkjet Fax
How to fax from a samsung fax machine
hi friend,
Step 1Create a cover letter to use saying who the document is for and from as well as the intended fax number and your phone number. This alerts the office or home the fax is sent to who it is intended for. Place cover letter on top of your documents and insert them into the fax machine feeder facing in the direction the machine specifies.
  • Step 2Enter the fax number into the machine. There will be a number pad just like a phone on the fax machine. Carefully type in the number so you do not make any mistakes, as it is difficult to know when you have dialed a wrong fax number.
  • Step 3Hit the send key once you have properly entered all of the numbers into the machine. This will initiate the sending of the documents. The send key should be larger than the others and easy to locate. Traditionally, it is placed next to or below the keypad.
  • Step 4Wait for your documents to pass through the machine and collect them when finished. Whatever you are sending will pass through a series of rollers that feed it through the machine and copy it digitally.
  • Step 5Look for a confirmation page to print. This will tell you whether or not your fax successfully went through.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); })hope this helps u
    please rate me....................
    thak u for using fixya
    Dec 01, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
    How to programm my fax number
    Here is a link to your Canon LaserClass 9000 users guide, unfortunately it was scanned 90 degrees off.
    Setting up group dial will allow you to send to multiple locations with only one scan of document(s). Programming fax number should be located on page 3-5.
    Oct 16, 2009 | Canon LaserClass 9000L Plain Paper Fax
    How to send a group fax for panasonic UF-8000
    For a one time action
    Press the first one touch number
    Press Set
    Press the second one touch number
    Press Set
    etc, etc.
    When all numbers are entered, put the document in and press START
    To permanently set up a GROUP
    Press 73 SET
    Select GROUP
    press the stations you want to be in the
    group one after another
    press PROGRAM 1 key
    Name the group
    press set.
    Jan 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
    WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
    Hope this helps.
    1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
    2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
    Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
    NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
    Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
    Jul 23, 2008 | Xerox Office Equipment & Supplies
    Brother 4750e
    This problem could be Phone line problem, or hardware failure or receiver's (the machine of the person whom you are sending the fax) machine problem and so on. First, let's check the line, if you have another Phone line, please dial from the number to your number, also, connect the currently connected line to a receiver and call a Land-line number, if the outgoing or incoming is ok, the proceed forward, otherwise, you telephone operator should check the line.
    Sometimes, sending fax to a particular number doesn't work, to make sure, try sending a fax to another number.
    If the line which is connected to the machine is extended from another machine such as Receiver, Switch, etc... unplug them and connect the fax machine directly to the Line.
    It's also important to adjust the compatibility mode, to do this, follow the steps below:
    • Press Menu.
    • Press the up or down arrow key to select Fax.
    • Press OK.
    • Press the up or down arrow key to select Miscellaneous.
    • Press OK.
    • Press the up or down arrow key to select Compatibility.
    • Press the left or right arrow key to select Basic (for VoIP).
    • Press OK.
    • Press Stop/Exit.
    If you place the scanning document/file on the auto-sheet feeder, you can help it pulling inside the passage or you can use the glass (flatbed) instead. Sometimes, this small mistakes with the sheet-feeder creates this problem. You can also clean the rollers inside the ADF (auto document feeder) passage.
    If all of the above measure don't help, I would suggest you to call brother and seek their help. The rest is with mechanical or we can say hardware or firmware related issue. (use this form to contact Brother)
    I wish you good luck.
    Thanks for using FixYa.
    Jun 10, 2008 | Brother IntelliFAX 4100 Laser Fax
    Speed dial list
    ***Storing a Number for Speed Dialing*** 1 Press Phone Book on the control panel. 2 Press Phone Book or the scroll button (􀂥 or 􀂊) to display ?Store&Edit? on the bottom line of the display. Press Enter. 3 Press Enter when ?Speed Dials? appears on the display. The display prompts you to enter a location number, showing the first available number. 4 Enter a one or two-digit speed dial number between 0 and 79, using the number keypad or scroll button (􀂥 or 􀂊), and press Enter. If a number is already stored in the location you chose, the display shows the number to allow you to change it. To start over with another speed-dial number, press Upper Level. 5 Enter the number you want to store using the number keypad and press Enter. To insert a pause between numbers, press Redial/Pause. A ?-? appears on the display. 6 To assign a name to the number, enter the name you want. For details about entering characters, see page 1.14. If you do not want to assign a name, skip this step. 7 Press Enter when the name appears correctly or without entering a name. 8 To store more fax numbers, repeat steps 4 through 7. To return to Standby mode, press Stop/Clear. ***Sending a Fax using a Speed Number**** 1 Feed the document(s) face up into the ADF. For details about loading a document, see page 2.2. 2 Adjust the document resolution to suit your fax needs. See page 2.3. If you need to change the darkness, see page 1.20. 3 Enter the speed dial number. ? For a one-digit speed dial number, press and hold the appropriate digit button. ? For a two-digit speed dial number, press the first digit button and hold the last digit button. The corresponding entry?s name briefly displays. 4 The document scans into the memory. The fax number stored in the speed dial location is automatically dialed. The document is sent when the remote fax machine answers
    Aug 17, 2007 | Samsung SF-560 Plain Paper Laser Fax
    Canon LaserClass 2060P Plain Paper Fax Logo
    old marine
    old marine
