Question about Vivitar ViviCam 5355 Digital Camera
The trouble of my camara is the follow I turn on
The trouble of my camera is the follow: wen I turn on the camera it automatically turn off
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 16, 2009
I turn on my camara and then the lens makes a noise and it turns of right away,i charge the battery (fully) and it still turns off
maybe because you have a lens error trouble, Lens errors (system errors) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:wish you luck thanks
Feb 21, 2012 | Sanyo VPC-X1250 Digital Camera
I got a Cannon PIXMA mp480 printer and downloaded drivers (two of them available from my computer's automatic detection). Now I can print and copy, but can not scan. The error message said" Can not...
Seeing the troubles automatic detection brings up, I would try downloading from cannon's official site.
Here is a link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp480#DriversAndSoftware
Godspeed,
Rodrick
Don't forget to rate my solution!
Apr 24, 2011 | Office Equipment & Supplies
Trying to copy photos to a folder using Microsoft Scanner & Camera Wizard. Camara is on and is connected to my PC with a USB cable, but the computer can not detect the camara.
First, check both ends of the USB cable to be sure that the ports and the plugs are properly seated so that the metal pins are able to transfer data. Restart Windows with the cables plugged in, and the camera should be recognized. You also MUST have the camera turned ON in order for the computer to read the fact that it is connected. If these suggestions fail, check your Microsoft Computer Management program to be sure that PlugnPlay devices are automatically recognized by your system.
Have fun with your photography!
Sciencewoman
Mar 31, 2011 | Samsung SL202 Digital Camera
WORKING CAMERA WONT TAKE MEMORY CARD
It's possible the camera won't take an sdhc card. Or maybe you just need to move the slide switch on the side of the card to unlocked or that you need to format the card in the camera.
Dec 26, 2009 | Cameras
Gigaware Camera Driver Needed, Is download Available
scan your system by entering the following websites. www.officialdrivers.com www.driverguide.com The appropriate drivers will be automatically selected and will be installes
Oct 12, 2008 | Video Game Consoles & Games
Casio EXILIM camera lens will not extend fully!!!
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
Jun 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Samsungs850 no pic in view finder
This is new. I see that according to the illustration, there is no Optical Viewfinder- thus you need the the screen to compose the images - Is this correct? As this camera is new to you carefully read up the instruction manual - especially the set up routine. If after a day or so you are still in trouble - take it back to the store for replacement. Do not interfere with the camera.
Jun 12, 2007 | Samsung S850 Digital Camera
Vivitar ViviCam 5355 Digital Camera Logo
71 people viewed this question
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
