Question about Maytag Neptune FAV6800AW Top Load Washer
Loud noises, sounds like it is out of balance. i have had the drum balanced before, but I want to try to do it myself this time. any help?
  • 526 Answers
Is your machine an FAV6800AW or FAV9800AW if so I will try to help.
Posted on Nov 16, 2009
Loud continous noise when drying
What type of noise exactly? Does it sounds like a thumping/whining/whistling or cracking noise? Have you tried to see if the tub/drum is not balanced any more?
Sep 09, 2012 | Frigidaire Dryers
Error code warning my load is out of balance
If the drum spin noise is loud your bearings need replacing.
If the bowl(drum)goes out of balance with nothing in it your bowl needs to be replaced.
Sep 03, 2012 | Fisher and Paykel Washing Machines
Yes I have 6 units of the DLE5955W dryer and one of the units vibrates when the unit is on. I thougth at first maybe it had a loose foundation or something wasn't lock do correctly, but all those...
Hey Ryan,,, did you just buy these for commercial use? Sounds like one of them missed the "balance drum" operation..or the "balancer guy" goofed the set-up..
Warranty should cover it!! .. Don't tell where you bought it its a commercial usage.
May 31, 2017 | LG DLE5955 Dryer
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
Washer is out of balance. it just leans to the left side and makes loud noise like metal on metal.
It sounds like your drum support, and/or balance mechanism inside the washing machine has broken. You will need to open your Washing machine and inspect the Drum Support, and the balance mechanism. Hook it back up or replace it if it is broken.
Feb 27, 2011 | Washing Machines
Making a loud noise when on the spin cycle and not balanced
It could be a drum spring has broken or stretched too far, there is too much of a heavy load in the drum, or the bearing needs replacing.
Sep 11, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 20, 2009 | Kenmore Washing Machines
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Loud dryer
  • it sounds like a bad roller. if you know how to take the drum out of the dryer then you can do this repair. no special tools are required.
  • you can get step by step (with pictures) instructions at this site.
  •  www.fixitnow.com
Jul 02, 2008 | Kenmore 72982 Gas Dryer
WF865 noise when spinning
Washers have to be balanced. Some have balance adjusters either inside the dryer as explianed above or on the bottom to level the washer. try to balance it by turning the bolts slightly or the bottom portion of the washer to level it. Or else they want to shake apart. Also by distributing the clothes evenly so it won';t be all to one side can help. do not tighten the screws all the way. Just tighten them to the point of getting the right balance.
Jun 16, 2008 | Hotpoint Ultima WF865 Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
94 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
