Question about Samsung DVD-VR357
Power problem My Vr357 will not turn on. I repaced the fuze. Still have a problem. Any suggestions? Dave
  • donna mcgill May 11, 2010
    have you checked your cables and test that they are working correctly? maybe your power plug isn't in all the way.. double check all your cables and be sure everything is in tightly.. maybe unplug and then replug it in.. how old is it? have you tried the manufacturer site? let me know what i can do to help..
  • 121 Answers
Just following up to see if this issue is resolved? If so, was I able to help at all in your solution? please let me know if you require additional would be wonderful:)..
Posted on Feb 26, 2008
Where can i find the fuse to replace for my cig lighter
It will be in the main fuze box under the hood or in front of your knees, because there are usually other things taken off that fuze. Check the fuze box lid and see if it shows the cig lighter but it may only show something like the blower of some other ancillary item. Go through the switches etc and see if anything else has failed, it might help. The alternative is that the fuze is good but your cig unit has failed. Don't rip the dash out until you are sure.
May 17, 2014 | 1995 GMC Suburban
Fridge did start up when turn th/stat 1/4 turn. apparently switch is sticking?? where and what to do now? can I get a repacement part?
if you have a kenmore service agent get the thermostat from them
if not call in a technician and he will source a suitable unit
Jan 31, 2018 | Kenmore Refrigerators
How do you make the scroll wheel turn again?
Your wheel may be stuck because dirt has worked its way into the wheel.
I have 3 ideas--
1) Get a can of computer duster, and try blowing the dirt out from around the wheel, outside and inside edge.
2) Sansa Fuze user 'tenzip' suggests dipping the player, while turned off, in DISTILLED water, if you believe the wheel has something sticky and water-soluble-- THEN let it drain, THEN put the player in a bag of uncooked rice for up to a week. The rice will pull the rest of the water out of the player.
Full discussion may be found here;
3) If 1) and 2) fail, you may want to try opening the player, disassembling and cleaning it, and then putting it back together. Directions with pictures can be found here;
Oct 09, 2011 | SanDisk Sansa Fuze MP3 Player
The fuse box for is located on the drivers side under the hood near the break master cylinder on the fire wall. Was just having the same problem since I lost my manuals. Let me know if you find a diagram of the fuse block. :D
Jun 13, 2011 | 2006 Chrysler Crossfire
I need a power cord for a Tournament Master HR Bottom Line fish locator. Where can I find this cord?
Do you still need the power cable? I have a new unopened power cable.
Feb 10, 2011 | Boating
Vr357 no power
If you take the top off of the unit there should be a glass fuse right behind the power chord. If you have a multimeter you can check and see if the fuse is ok by setting the meter on 120 ground the black wire to the chassis and put the red probe on the fuse out side to check for power. If the fuse is bad you can replace it, but you may have to unsolder it.
Jan 21, 2010 | Samsung DVD-VR357
My sansa fuze will not turn on even when i hook it up to the computer?
Hi, i suggest you check the battery because it is possible that the battery as gone bad. Replace the battery and try to power on to see if it will come up.
If same problem persist, you can get a technician to help check the power button and panel.
I wish you best of luck.
Jan 07, 2010 | SanDisk Sansa Fuze MP3 Player
No power light, cord is fine, changed outlets, still no picture or sound
Replace Fuse or power supply as a whole. You be glad you did . remeber is you do not know how to do this seek expert help, Thanks
Sep 29, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
How to record ?
I don't know a whole lot about electronic equipment, but I've never seen anything connected in so many ways at the same time. Maybe the antenna and one other type of connection. The different signals from all the connections are probably confusing each other. I would try one connection at a time to see if the problem improves. Good Luck.
Dec 16, 2007 | Samsung DVD-VR357
Samsung DVD-VR357 Logo
Jerry Greenberg
Jerry Greenberg
